Clone TChart to TQRChart
Lenfors
Post by Lenfors » Mon Sep 16, 2013 12:23 pm
Hello!
I'm trying to copy my TChart to a TQRChart for printout. Most things seem to work but all my custom axis seems to dissapear!?
AQRChart.Chart.Assign(AChart);
for t:=0 to AChart.SeriesCount-1 do
CloneChartSeries(AChart[t]).ParentChart:=AQRChart.Chart;
I cant find any CloneChartAxis! How do I clone the axis and assign all my cloned series to them?
Best regards, Mikael
Re: Clone TChart to TQRChart
Post by Yeray » Tue Sep 17, 2013 2:47 pm
Hi Mikael,
For printing, it may be easier to use a bitmap. You could have a TQRImage in your TQuickRep and then assign the chart bitmap exported with TeeBitmap function.
This works fine for me here:
procedure TForm1.AssignToImage(AQRImage: TQRImage; AChart: TChart);
var tmpBitmap: TBitmap;
  tmpBitmap:=AChart.TeeCreateBitmap;
  AQRImage.Picture.Bitmap:=tmpBitmap;
  AQRImage.Width:=tmpBitmap.Width;
  AQRImage.Height:=tmpBitmap.Height;
I see the Assign function copies the series and the custom axes from the origin chart to the destination chart. What it isn't copying are the relations between the series and the custom axes. I've added it to the wish list to be revised forfuture releases (TV52016721).
In the meanwhile, if you know the relations, you could manually assing them after the code you posted above, or after calling the CloneChart function:
  for t:=0 to AQRChart.Chart.SeriesCount-1 do
    AQRChart.Chart[t].CustomVertAxis:=AQRChart.Chart.CustomAxes[t];
Or:
  CloneChart(AQRChart.Chart, AChart, Self, false);
Lenfors
Post by Lenfors » Mon Sep 23, 2013 1:47 pm
Hello!
Ok, thanks!
I cant use the BitMap solution as there are several changes done on the printout in respect to the original.
The problem is that i have about 40 series spread over about 30 different scales so your "one to one" copy does not work.
Any easy code to find out which custom axis i should apply each copied serie to?
Regards, Mikael
Post by Narcís » Tue Sep 24, 2013 8:30 am
Hi Mikael,
The examples with CustomVertAxis and CustomAxes Yeray posted in his last reply don't help with this?
Lenfors
Post by Lenfors » Wed Sep 25, 2013 1:32 pm
Hello!
No it does not work, if you check his code:
He assumes a 1:1 relationship between the Series and the CustomAxes but some of my Seried share the same axes!
Post by Narcís » Wed Sep 25, 2013 1:43 pm
Hi Mikael,
I see, it probably should be something like this:
    AQRChart.Chart[t].CustomVertAxis:=AChart.Chart[t].CustomVertAxis;
Where series axes settings are copied from one chart to the other.
Lenfors
Post by Lenfors » Wed Sep 25, 2013 1:45 pm
Ok, thanks. I'll test it!
Lenfors
Post by Lenfors » Mon Sep 30, 2013 8:42 am
Sorry, but I can't make it work!
I'm using TeeChart 8.07, is this maybee the problem. Is this functionality improved in later version?
My latest try is below. The problem is I can't get my custom axes to be copied currectly. On my original Chart I can see 20 series but on my report there are only two. Probably they are to high or low to be visible as their axes are not copied/assigned correctly.
Best regards, MIkael
// Copy chart
QRDataChart.Chart.FreeAllSeries;
QRDataChart.Chart.Assign(DataChart);
// Copy series
For I := 0 To DataChart.SeriesCount - 1 Do
Begin
CloneChartSeries(DataChart).ParentChart := QRDataChart.Chart;
QRDataChart.Chart.Series.CustomVertAxis := DataChart.Series.CustomVertAxis;
End;
Post by Yeray » Tue Oct 01, 2013 3:09 pm
Hi Mikael,
Give it a try to the following. I'm searching for the relations and assigning them accordingly. I'm only doing it only for the CustomVerticalAxis, but you shouldn't find problems to expand it for the CustomHorizontalAxis too if you also need it:
uses Series;
var i, nSeries: Integer;
  nSeries:=4;
  Chart1.View3D:=false;
  for i:=0 to nSeries-1 do
    Chart1.AddSeries(TLineSeries).FillSampleValues;
    if i>0 then
      Chart1[i].CustomVertAxis:=Chart1.CustomAxes.Add;
      with Chart1[i].CustomVertAxis do
        StartPosition:=i*(100/nSeries);
        EndPosition:=(i+1)*(100/nSeries);
        Axis.Color:=Chart1[i].Color;
        LabelsFont.Color:=Chart1[i].Color;
  with Chart1.Axes.Left do
    EndPosition:=100/nSeries;
    Axis.Color:=Chart1[0].Color;
    LabelsFont.Color:=Chart1[0].Color;
  CopyChartToQRChart(Chart1, QRChart1);
procedure TForm1.CopyChartToQRChart(AChart: TChart; AQRChart: TQRChart);
var i, j: Integer;
  for i:=0 to AChart.SeriesCount-1 do
    if AChart[i].CustomVertAxis<>nil then
      for j:=0 to AChart.CustomAxes.Count-1 do
        if AChart.CustomAxes[j]=AChart[i].CustomVertAxis then
          QRChart1.Chart[i].CustomVertAxis:=QRChart1.Chart.CustomAxes[j];
Post by Yeray » Mon May 26, 2014 11:00 am
Hi again,
I've moved the TV52016721 ticket to the public tracker.
http://bugs.teechart.net/show_bug.cgi?id=780
