smoothing does not work in my design?
sct
Post by sct » Wed Aug 14, 2013 12:32 pm
The example show smoothing works but the way I use the 2d charts it does not.
here is my draw 2d function. Did I do anything wrong?
 chart.prototype.draw = function ()
     {//makes a 2d chart
         this.UIDiv.removeChild( this.canvas );
         this.canvas = document.createElement( 'canvas' );
         this.canvas.id = "canvas" + this.id;
         this.canvas.width = this.canvasData_width;
         this.canvas.height = this.canvasData_height;
         this.canvas.style.zIndex = this.canvasData_zIndex;
        // this.canvas.style.background = "#ffffff"
         this.UIDiv.appendChild( this.canvas );
         this.Chart1 = new Tee.Chart( "canvas" + this.id );
         this.annot = new Tee.Annotation( this.Chart1 );
         this.annot.position.x = 15;
         this.annot.position.y = 20;
         var anno = this.annot
         this.annot.mousemove = function () { this.text = ""; }
         if ( this.type == "Function" )  this.addData( this.Xdata, this.Ydata, .05, "ellipse" );
         else if ( this.type == "Table" )
             for ( z = 0; z < this.Zdata.length;z++ )
                 this.addData( this.Ydata, this.Zdata[z], .05, "ellipse" );
         this.Chart1.tools.add( this.annot );
         this.Chart1.title.text = "";
         this.Chart1.axes.left.title.text = this.labelY;
         this.Chart1.axes.bottom.title.text = this.labelX;
         this.Chart1.tools.add( new Tee.DragTool( this.Chart1 ) );
         this.Chart1.draw();
sct
Re: smoothing does not work in my design?
Post by sct » Wed Aug 14, 2013 12:34 pm
this is my addData where I try and add something.
 chart.prototype.addData = function ( xdata,ydata,smooth,style )
         var dat = this.Chart1.addSeries( new Tee.Line() )
         dat.smooth = smooth;
         dat.data.values = eval( "[" + ydata.toString() + "]" );//will not take an array dirrectly, must eval its string.
         dat.data.x = eval( "[" + xdata.toString() + "]" );
         dat.data.labels = xdata
         dat.cursor = "pointer";
         dat.colorEach = "yes";
         dat.pointer.style = style;
         dat.pointer.visible = true;
         dat.format.stroke.fill = "red"
         var anno = this.annot;
         dat.onclick = function ( series, index, x, y )
             var xValue = series.data.x ? series.data.x[index].toFixed( 0 ) : index.toFixed( 0 );
             anno.text = "X: " + xValue + "\nY: " + series.data.values[index].toFixed( series.decimals );
             series.chart.draw();
         this.datas.push( dat );
Post by Yeray » Mon Aug 26, 2013 10:21 am
Note you have to include the teechart-extras.js.
sct
Post by sct » Mon Aug 26, 2013 12:06 pm
steema/source/teechart-extras.js is included. Is it the ordering?
Post by Yeray » Tue Aug 27, 2013 3:51 pm
Please, try it as in the demos.
I had to modify your code to make it work for me here, but it seems to work fine.
I had to define:
		 this.Xdata = ["0", "1", "2", "3", "4"];
		 this.Ydata = ["0", "30", "40", "45", "50"];
		 this.type = "Function";
And to comment out removeChild, appendChild and datas.push.
test.zip
(1.19 KiB) Downloaded 1314 times
sct
Post by sct » Wed Aug 28, 2013 12:22 pm
well it took me a long while to figure it out but i found it. You changed the 3rd parameter in addData to a .5 instead of my .05. This is the smoothing setting I guess .05 was not enough. Had to use a compare plugin to figure it out.
Post by Yeray » Thu Aug 29, 2013 10:47 am
I'm glad to see you found it.
