I'm getting the following with the code below and TeeChart Pro v2012.06, XE2 in a Win7 x64 machine:
- Marks_align.png (31.29 KiB) Viewed 17031 times
uses Series, TeeGDIPlus;
var i: Integer;
tmp: Double;
Chart1.Canvas:=TGDIPlusCanvas.Create;
with Chart1.AddSeries(TBarSeries) as TBarSeries do
for i:=0 to 5 do
tmp:=random*75+25;
Add(tmp, FormatFloat('#0.#', tmp) + ' MB');
Marks.Style:=smsLabelPercent;
Marks.MultiLine:=true;
Could you please try the code above to see if you still reproduce the problem with it?
Otherwise, it would mean you are doing something different than me. If that's the case, please, modify the code so we can reproduce the problem here, or arrange a simple example project we can run as-is for the same.
