TeeChart for JavaFX
MHA
TeeChart for JavaFX
Post by MHA » Fri May 25, 2012 1:14 pm
Hi
Will there be a TeeChart version for JavaFX? Anything planned?
Best Regards
Michi
Re: TeeChart for JavaFX
Post by Yeray » Mon May 28, 2012 12:52 pm
Hi Michi,
I'm afraid we don't have plans to implement a native JavaFX version of TeeChart. However, I'm not sure if the actual Java version can be embedded into a JavaFX project.
MHA
Post by MHA » Tue May 29, 2012 7:33 am
Hi Yeray
Thank for for the answer.
Yes that may be a possibility, but i think they removed support for swing components in JavaFX 2.0...
Best Regards
Michi
Post by Yeray » Tue May 29, 2012 8:04 am
Hi Michi,
And what about the TeeChart Java SWT component?
http://docs.oracle.com/javafx/2/swt_int ... bility.htm
MHA
Post by MHA » Tue May 29, 2012 12:13 pm
Hi Yeray
Yes that would work (for swing too), but then you still have a mix of swing and JavaFX (where JavaFX is embedded).
I was looking for a way to eliminate swing completly once we switch over to JavaFX.
Best Regards
Michi
Post by Marc » Tue Feb 06, 2018 12:09 pm
In response to recent questions on this subject, TeeChart is not a native JavaFX component. It may be included in a JavaFX project in the following way, using SwingNode:
public class JavaFXChartApp extends Application {
    @Override
    public void start(Stage primaryStage) {
        javafx.embed.swing.SwingNode swingNode = new SwingNode();
        com.steema.teechart.TChart mChart = new com.steema.teechart.TChart();
        swingNode.setContent(mChart);
        mChart.getChart().getAspect().setView3D(false);
        ColorGrid cGrid = new ColorGrid(mChart.getChart());
        cGrid.fillSampleValues();
        StackPane root = new StackPane();
        root.getChildren().add(swingNode);
        Scene scene = new Scene(root, 800, 450);
        primaryStage.setTitle("TeeChart test form");
        primaryStage.setScene(scene);
        primaryStage.show();
     * @param args the command line arguments
        launch(args);
