Not able to take print of Graph generated in IE9
Reval
Post by Reval » Mon Nov 07, 2011 1:43 pm
I am using "TeeChart Pro ActivX Control v5" to generate graph. When I try to take the print of the graph using IE9, it displays a cross instead of graph in the printout. It is working perfectly fine with previous versions of IE.
I want to know:
1. Does "TeeChart Pro ActivX Control v5" support printing in IE9?
2. If yes, what could be the problem at my end?
3. If No, then which version of this ActiveX control support this behaviour?
An early response is much appreciated as I need to reply to the client.
Re: Not able to take print of Graph generated in IE9
Post by Yeray » Tue Nov 08, 2011 2:55 pm
Hello Reval,
I think it should be printed correctly. But,
Are you printing the whole page from the browser, just the chart using the chart editor, or how exactly?
Is the problem reproducible with the examples included with the installation or just in a particular application?
