Activation Fails during install:TeeChart Java v1 for Android
Andrew Park
Post by Andrew Park » Thu Jul 21, 2011 7:00 am
I am trying to install "TeeChart Java v1 for Android", but fails with "Online activation".
What I did so far is:
1. Download the files
2. Execute TChart.Installer.jar
3. Enter ID, password etc and select "Online activation via internet"
4. Message box appears that says "Activation Failed"
I'm running Windows 7 32-bit OS, your help will be appreciated.
Andy
Re: Activation Fails during install:TeeChart Java v1 for Android
Post by Yeray » Fri Jul 22, 2011 5:09 pm
Hello Andy,
We're investigating it and we'll be back to you asap. Excuse us for the inconvenience.
Post by Marc » Fri Jul 22, 2011 9:47 pm
Hello Andrew,
We've sent an email to your registered email address including an activation code that you can use to activate the installation whilst we check what problem has occurred with the online process. Please check your email inbox for the message from us.
Apologies for the inconvenience caused.
Post by Marc » Fri Jul 22, 2011 10:12 pm
Hello Andrew,
We have made a modification to the online activation process, you should now be able to activate online too.
Bizeasset
Post by Bizeasset » Mon Aug 01, 2011 1:08 am
We have just downloaded the same product on Friday 29th July. It worked for us then.
Chris
Bizeasset
Post by Yeray » Mon Aug 01, 2011 8:52 am
Hello Chris,
Thanks for the info.
