ColorEditor ?
Uli
ColorEditor ?
Post by Uli » Fri Jul 30, 2010 9:33 am
when I use
        Dim dlg As New Editors.ColorEditor
        If Not dlg.ShowDialog = Windows.Forms.DialogResult.OK Then Return
then I see this:
Why?
Best regards
Uli
Re: ColorEditor ?
Post by Sandra » Fri Jul 30, 2010 10:41 am
Hello Uli,
If you want call the EditorColor and see correctly its dialog, you need use next lines of code:
Private Sub button1_Click(sender As Object, e As EventArgs)
	Steema.TeeChart.Editors.ColorEditor.Choose(tChart1(0).Color)
Could you please, say if previous lines work as you want in your application?
I hope will helps.
Uli
Re: ColorEditor ?
Post by Uli » Fri Jul 30, 2010 11:36 am
Hi Sandra,
thanks for the fast response.
The code works in this manner:
btnColor.BackColor = Editors.ColorEditor.Choose(btnColor.BackColor)
btnColor.BackColor is a buffer for the chosen color.
Best regards
Uli
Re: ColorEditor ?
Post by Sandra » Mon Aug 02, 2010 8:56 am
Hello Uli,
Thanks for information. I glad that solution works fine for you:)
