TreeMap Series - OnClick - ValueIndex always Zero...
TimeAcct
Post by TimeAcct » Mon May 31, 2010 5:07 am
I have been playing with the TreeMap series. Very nice and fairly easy to use - now that I have found the sample projects.
However, once piece of code - the OnClick Event does not seem to be working as I would expect.
When I run the OnClick (by clicking on various parts of the Chart) I always get a value of Zero for the ValueIndex. I thought this was supposed to be the value pointing to the item in the Series that was clicked?
procedure TForm_OutputTreeMapView.Chart_TreeMapClickSeries(Sender: TCustomChart;
Series: TChartSeries; ValueIndex: Integer; Button: TMouseButton;
===> If TDirInfo(CurrNode.Data).DirSize = TTreeMapSeries(Series).Item[ValueIndex].Value Then Begin
This line of code is always wrong - because ValueIndex is always zero...
Is this a bug in the new component? Or do I have to determine which item on the TreeMap was clicked in a different way?
Any thoughts would be appreciated.
Bradley MacDonald
TimeAcct Information Systems
brad_AT_timeacct_DOT_com
Re: TreeMap Series - OnClick - ValueIndex always Zero...
Post by Yeray » Mon May 31, 2010 9:45 am
Hi Bradley,
Yes, you are right. Please note that this is a quite new series and it would probably need some improvements.
I've added it to the wish list to be implemented in future releases (TV52014920).
TimeAcct
Post by TimeAcct » Mon May 31, 2010 1:00 pm
Hello Yeray,
Can you provide a rough idea when this might be patched? It is a fairly important feature to us.
Bradley MacDonald
Post by Yeray » Tue Jun 01, 2010 10:18 am
Hi Bradley,
We've taken a deeper look at it and we've already implemented it so it will be available in the next maintenance release.
As you are a source code customer, I'll send you the unit with the changes to the mail account you have registered in this forums.
