Position text on node
Lenfors
Post by Lenfors » Tue May 18, 2010 2:43 pm
When I assign icons (32*32) to my nodes the text is not repositioned at the right of the icon, its written right over it!? How can I position the text?
Regards, Mikael
Re: Position text on node
Post by Yeray » Wed May 19, 2010 12:03 pm
Hi Mikael,
I'm trying to reproduce the problem with the following code:
uses TeeTree, PNGImage;
var Tree1: TTree;
    TreeNodeShape1: TTreeNodeShape;
  Tree1:=TTree.Create(self);
  Tree1.Parent:=Self;
  Tree1.Align:=alClient;
  TreeNodeShape1:=TTreeNodeShape.Create(self);
  TreeNodeShape1.Text.Text:='my first node';
  TreeNodeShape1.Tree:=Tree1;
  TreeNodeShape1.Image.LoadFromFile('C:\tmp\32_button_red.png');
//  TreeNodeShape1.ImageAlignment:=iaCenter;
Could you please explain what would you expect to obtain or what modifications are needed to reproduce the problem?
Lenfors
Post by Lenfors » Tue May 25, 2010 9:18 am
I use the following code to create then nodes:
Node := Tree.AddRootObject('Group ' + intToStr(I), TNodeData.Create);
Node.AutoSize := True;
Node.Height := 34;
Node.Font.Size := 12;
Node.Border.Hide;
Node.ImageListIndex := 0;
After some testing I found that it's the "Node.Height := 34;" command that is the problem! When I comment this line the text is positioned right of the icon.
The icons are 32*32 so if I don't set the hight to 34 there is no space between them!.
Mikael
Post by Yeray » Tue May 25, 2010 2:18 pm
Hi Mikael,
You could add some offset:
Node.Text.HorizOffset:=32;
Lenfors
Post by Lenfors » Tue May 25, 2010 5:15 pm
No, the HorizOffset and VertOffset only positions the text within the node! I want to increase the distance between two nodes in Y-direction. As default the icons added to the nodes are positioned exactly below each other!
Regards, Mikael
Post by Yeray » Wed May 26, 2010 9:15 am
Hi Mikael,
So the problem may be in the height? Could you please try the following?
var t: Integer;
  with Tree1.AddRoot('Root') do
    Tree1.Items[0].Height:=32;
    Tree1.Items[0].Width:=Form1.Canvas.TextWidth(Tree1.Items[0].Text.Text);
    for t:=1 to 20 do
      AddChild('Node '+IntToStr(t));
      Tree1.Items[t].Height:=32;
      Tree1.Items[t].Width:=Form1.Canvas.TextWidth(Tree1.Items[t].Text.Text);;
