Show All Labels option for left axis
chips
Post by chips » Mon Dec 21, 2009 2:36 pm
Hi, I'm trying to set the "Show all labels" option for the Left axis through the API... is this possible?
e.g. I have a form which allows users to customize the Increment setting for the Y-Axis. In the example below, the user sets the increment to .5.
However, when the chart is generated, TChart determines whether there is enough room to display all the labels. If TChart decides to hide some incremental labels, the user is forced to manually configure the setting. We need to be able to check that box programmatically, so the extra step isn't necessary.
Thanks in advance,
-ChipS
Re: Show All Labels option for left axis
Post by Yeray » Mon Dec 21, 2009 3:55 pm
Hi Chris,
This checkbox internally sets the labels separation to 0 (when unchecked) or to 10 (when checked). The same can be done, for example with the following:
TChart1.Axis.Left.Labels.Separation = 0
