prevent OnMouseMove event triggering
TonyHunt
Post by TonyHunt » Mon Aug 17, 2009 12:09 pm
I would like to prevent the OnMouseMove event triggering when the cursor is NOT over the actual chart drawing area.
Is this possible?
By the way what is the correct terminology for "the actual chart drawing area" :oops:
Tony
Re: prevent OnMouseMove event triggering
Post by Yeray » Tue Aug 18, 2009 9:49 am
Hi Tony,
I'm afraid you should test if the mouse cursor is in the target area manually:
  Y: Integer);
var dummyPoint: TPoint;
  dummyPoint.X := X;
  dummyPoint.Y := Y;
  if PtInRect(Chart1.ChartRect, dummyPoint) then
    //your code
So if you mean the rectangle formed by the left and the bottom axes, we call it "ChartRect". 8)
TonyHunt
Post by TonyHunt » Mon Aug 24, 2009 10:27 am
Thank you very much, that's exactly what I needed.
Please let me know if you ever get to visit the U.K.,
I would be delighted to introduce you to a quaint old English custom called "Pub Crawling".
Tony
Post by Yeray » Mon Aug 24, 2009 11:26 am
Hi Tony,
It's a pleasure trying to be helpful!
Thanks for the invitation! It looks culturally really interesting! ;)
