MouseWheel Scrolling doesn't trigger OnScroll
skassan
Post by skassan » Fri Oct 09, 2009 8:42 pm
The subject says it all. The same is probably true if the AxisScroll or AxisArrows tools are used. All three behave differently than manually panning with the right mouse button. After panning around with the right mouse button, UndoZoom restores the chart to it's "original" axis values. Using the MouseWheel to scroll does not. Neither do the AxisScroll or AxisArrow tools in the Demo program.
Re: MouseWheel Scrolling doesn't trigger OnScroll
Post by Narcís » Tue Oct 13, 2009 11:37 am
Hi skassan,
Yes, I could reproduce this here. I'll add your request to the wish-list to be considered for inclusion in future releases. In the meantime you can reset scroll implementing the OnUndoZoom event like this:
procedure TForm4.Chart1UndoZoom(Sender: TObject);
  Chart1.Axes.Left.Automatic:=true;
  Chart1.Axes.Bottom.Automatic:=true;
konzeptum_sd
Post by konzeptum_sd » Tue Mar 05, 2024 5:49 pm
I'd like to bump this old request, based on a different use case.
We use the OnScroll event to synchronize the (horizontal, i.e. date) position of our Gantt chart with a corresponding workload chart we display below it. When panning via mouse button this works by simply setting
dbChartLoad.BottomAxis.SetMinMax(dbChartGantt.TopAxis.Minimum,
                                 dbChartGantt.TopAxis.Maximum);
or vice versa in the OnScroll event handler.
Since one of our recent updates (probably the Bug #2433 fix for horizontal-only mouse wheel scrolling), the charts now react to the mouse wheel - which is good - but they don't sync.
Our somewhat dirty workaround is propagating the actual scrolling by calling the other chart's corresponding protected function from the mouse wheel event handler:
type
  TkoDBChartAccessor = class(TDBChart);
var
  fSyncMouseWheelTarget : TDBChart;
procedure TSomeFrame.dbChartGanttOrLoadMouseWheel(Sender: TObject;
                       Shift: TShiftState; WheelDelta: Integer;
                       MousePos: TPoint; var Handled: Boolean);
  if Sender = fSyncMouseWheelTarget then
      //end recursion: don't propagate any further, but don't prevent the
      //scrolling either
      exit;
  if Sender = dbChartGantt then
      fSyncMouseWheelTarget := dbChartLoad;
    end
  else //Sender = dbChartLoad
      fSyncMouseWheelTarget := dbChartGantt;
  try
    TkoDBChartAccessor(fSyncMouseWheelTarget).DoMouseWheel(Shift, WheelDelta,
                                                           MousePos);
  finally
    fSyncMouseWheelTarget := nil;
I also tried adding a TChartScrollBar but it did not trigger the OnScroll event either. Since I ran into some other trouble with it also, we postponed that. In any case, supporting the OnScroll-Event no matter the scrolling method would provide for a straightforward and clean solution.
Our current build version is 2023.37.230130.
Thanks in advance for checking again,
Stefan
Post by Yeray » Thu Mar 07, 2024 12:31 pm
Hello Stefan,
I'm afraid the request Narcís added was lost when we moved to bugzilla.
I've added it at #2683, and already fixed it.
So the next version should be triggering OnScroll event from the mouse wheel.
konzeptum_sd
Post by konzeptum_sd » Thu Mar 07, 2024 1:49 pm
ok, that. was. fast. Many thanks! :)
All the best,
Stefan
