BUG!!!
BUG!!!
Post by » Wed Feb 08, 2023 8:30 am
Y1 series display error
Y2 series display ok
This is a bug?
Data in attachment.
data.zip
(1.51 KiB) Downloaded 1615 times
Re: BUG!!!
Post by Yeray » Mon Feb 13, 2023 9:40 am
Try setting RoundFirstLabel to False:
Chart1.Axes.Left.RoundFirstLabel:=False;
Re: BUG!!!
Post by » Wed Feb 15, 2023 1:12 am
This is a bug!
Re: BUG!!!
Post by Yeray » Wed Feb 15, 2023 1:09 pm
I can reproduce the same behaviour at least since v2012.05.
Has this ever worked as you'd expect?
Re: BUG!!!
Post by Yeray » Wed Feb 15, 2023 4:12 pm
I've just added it to the public tracker #2588, and already fix it.
Re: BUG!!!
Post by » Thu Feb 16, 2023 1:25 am
So, is this really a bug?
Re: BUG!!!
Post by Yeray » Thu Feb 16, 2023 7:47 am
That depends on the description of the term "bug".
If you consider a "bug" is a functionality that changed its behaviour from output A to output B where A was the output a user expected, then this isn't a bug.
If you consider a "bug" is a functionality that doesn't work as a user expects, even if the program/library was never able or designed do it, then this is a bug.
But yes, we try to document both situations in bugzilla.
Re: BUG!!!
Post by » Mon Feb 20, 2023 9:40 am
Isn't this a bug?
Re: BUG!!!
Post by Yeray » Mon Feb 20, 2023 12:02 pm
The #2588 ticket is closed and the code is in the internal sources.
The example before the changes:
The example after the changes;
I believe you don't have TeeChart sources so I'm afraid you'll have to wait the next release. It should work as you expected.
Re: BUG!!!
Post by » Tue Feb 21, 2023 3:24 am
I bought the pro version. What do you mean by TeeChart sources
Re: BUG!!!
Post by Yeray » Tue Feb 21, 2023 7:57 am
The commercial versions include:
- TeeChart Standard (binary)
- TeeChart Standard with sources
- TeeChart Pro (binary)
- TeeChart Pro with sources
https://www.steema.com/product/vcl#pricing
The binary versions don't include TeeChart sources. The versions including sources can be modified by customers to fit their needs.
We use to explain what changes to apply to the sources to fix small issues to customers owning the sources so they can take advantage of it without having to wait for the next maintenance release.
Re: BUG!!!
Post by » Wed Feb 22, 2023 12:42 am
When will the next version be released?
Re: BUG!!!
Post by Yeray » Thu Feb 23, 2023 10:50 am
I'm afraid I can't tell you when the next maintenance release will be published. We'll try to publish TeeChart VCL versions quarterly.
