Good morning. I have a persistent problem with axis labels not showing on one axis, which I cannot solve. I use 4 custom axes to plots data from two sources against a common axis (the independent axis). The independent axis can be vertical or horizontal, and the labels are not visible in either case, so it does not appear to be related to custom axis settings. I have attached two images showing the problem for the vertical and horizontal case (no labels for the Tool Velocity axis).
I have tried setting LabelStyle of all axes to talValue and talAuto but to no avail. In the Graph Editor, Axis Items shows a single 0 if I use talAuto, and nothing if I use talValue.
The code is very complex but I have thoroughly checked that the code is the same for each of the two custom axes being used. Any idea of things that I could try?
Thanks and regards, Errol
Axis labels not showing
- Image_Horizontal.jpg (161.08 KiB) Viewed 7869 times
- Image_Vertical.jpg (146.58 KiB) Viewed 7869 times
Re: Axis labels not showing
I would like to cancel this **error**. My mistake - I had an increment of 10 and an axis range of 0 to 1. I will solve this by setting Auto Increment to true.
Many apologies for this.
Errol
Errol
Hello Errol,
No problem at all!
No problem at all!
