Left margin AreaLineChart
We use the AreaLineChart in our Xamarin Forms application.
But no matter what we set the WidthRequest to, there is always more left margin white space than on the right side.
We set the control to Center.
Cfr screenshot.
How can we get equal margins?
Cfr screenshot.
- AreaLineChart.png (294.4 KiB) Viewed 15705 times
Re: Left margin AreaLineChart
could you please share the code that you're using to change the chart aspect and data points to populate ?
I can't reproduce the problem here by using this area example.
Pep Jorge
http://support.steema.com
I will try to recreate a sample.
Seems our screen design is doing something, because the demo app I created to share does indeed not have this problem.
In other words, I need to digg deeper in our production app.
Sorry for the inconvenience and time, thanks for the tip.
Ha, found the difference!
When toggling the chart with IsVisible, it will be smaller!
Last edited by Bank Van Breda on Fri May 21, 2021 1:58 pm, edited 1 time in total.
So the problem is with graphs being rendered invisible and shown later...
Here I load the same graph twice on the page, the first one is just like your sample the second one has a bool bound to IsVisible and will become visible with the button click.
This will render it smaller! Cfr screenshots.
Do you still need extra info on code? I can supply the example if needed.
- Screenshot 2021-05-21 at 15.54.31.png (92.05 KiB) Viewed 15663 times
- Screenshot 2021-05-21 at 15.54.28.png (76.73 KiB) Viewed 15663 times
ok, it's very strange problem. Let me check here and back to you. If I need code you use will ask.
Pep Jorge
I've just checked here setting the Chart view visible and invisible by using a simple IsVisible code :
but all seems to work fine anyway.
Could you please send me the code that you're using in order to make it invisible at first ?
private void B_Clicked(object sender, EventArgs e)
AreaLineChart.IsVisible = !AreaLineChart.IsVisible;
Pep Jorge
I added the sample here : https://github.com/Depechie/Charting
It does not contain our license file of course
yes, you're correct, I'm able to reproduce the problem here.
For the moment still not found what's the cause of this. We will review more carefully in order to find a solution.
In meantime, would be an option to you to set invisible via code instead of doing it via binding ?
Pep Jorge
Not in our actual production app. Everything is abstracted away from the View and handled in the ViewModel...
