I need to have the plot area (area between axes) painted in white so I added some code in the OnBeforeDrawChart event. When I start the app the area inside the plot is painted with the default colour and once I move the mouse inside the event code executes well. Is there a way to fix this? I tried calling TChart.Draw when the form is shown but no luck.
I am using the latest TChart version
Issue with OnBeforeDrawChart
- Project1.zip
- (5.59 KiB) Downloaded 837 times
Re: Issue with OnBeforeDrawChart
Adding the aChart.Draw call at FormCreate works for me using RAD 10.3 Rio and TeeChart Pro v2018.26:
If you still find problems with this, please tell us what environment are you using.
Thank you for your reply, that seems to do the trick
