TSeriesBandTool with C++Builder 10.1
nh128
Post by nh128 » Tue Sep 11, 2018 5:36 am
I am trying to dynamically create a TSeriesBandTool tool in C++Builder 10.1 using code such as ...
TSeriesBandTool* ChartTool = new TSeriesBandTool(NULL);
TTeeCustomTool* customTool = Chart->Tools->Add(ChartTool);
TSeriesBandTool* Tool = dynamic_cast<TSeriesBandTool*>(customTool);
Tool->Series = MaxLine;
Tool->Series->Legend->Visible = false;
Tool->Series2 = MinLine;
Tool->Series2->Legend->Visible = false;
Tool->Brush->BackColor = TColor(16051931);
Tool->DrawBehindSeries = true;
Tool->Transparency = 50;
Tool->Active = true;
I am using TeeChart Pro v2017.21.170329 32 bit.
The code compiles and runs but the area between MinLine and MaxLine is not coloured.
Similar code works in another form where the TSeriesBandTool is statically created using the Chart Editor.
Can you help please.
Re: TSeriesBandTool with C++Builder 10.1
Post by Yeray » Wed Sep 12, 2018 10:10 am
We've tested it here and this seems to work fine here:
Find below the code I've tested with TeeChart Pro VCL/FMX v2018.25 and RAD Studio 10.1 Berlin:
    Chart1->View3D=False;
    Chart1->Legend->Hide();
    Chart1->AddSeries(new TLineSeries(NULL));
    Chart1->Series[0]->FillSampleValues();
    Chart1->Series[1]->FillSampleValues();
    TTeeCustomTool* customTool = Chart1->Tools->Add(ChartTool);
    Tool->Series = Chart1->Series[0];
    Tool->Series2 = Chart1->Series[1];
What TeeChart version are you using?
Could you please test the code above in a new simple test project?
