Still cannot use Legend Palette
I just upgraded to the latest TeeChart VCL 32 bit version and I am still having issues with the Legend Palette, once this object is added to a chart and the mouse goes inside the chart area I get this error message. Can you please provide some guidelines on how to identify and fix this issue?
- Screenshot_1.png (82.4 KiB) Viewed 40043 times
Re: Still cannot use Legend Palette
I'm not able to reproduce this problem with the latest version v2017.21.
I can only send you an executable that generates the error, if I send you the code you will not be able to reproduce is (just like the first time I reported this!). Here is the link https://www.dropbox.com/s/9h4ap9c7dtfa6 ... 1.zip?dl=0
I guess you mean here. Indeed, it seems I wasn't able to reproduce the "Control '' has no parent window" error at that time either.johnnix wrote:I can only send you an executable that generates the error, if I send you the code you will not be able to reproduce is (just like the first time I reported this!)
This is what I see with that exe. I can't find how to make it to crash:johnnix wrote:Here is the link https://www.dropbox.com/s/9h4ap9c7dtfa6 ... 1.zip?dl=0
Wow, how can this be possible? When I move the mouse over the chart I get the error (I included a screenshot from EurekaLog running, maybe someone could have some idea?)
Yes, the issue appeared with my Delphi XE7 version but after I upgraded to XE10 with a clean install I thought it would "magically" go away as it was almost obvious that this is an issue with my installation.... If anyone has any idea about this please let me know, I removed the legend palette from my app and wish to include it again.
- Screenshot_1.png (71.77 KiB) Viewed 40001 times
Could you please output the TeeChart version in the same application at runtime?
Just to verify the correct version is being used.
uses TeeConst;
Caption:=TeeMsg_Version;
This is how it works for me:
So could this be related to some sort of an OS problem? I cannot understand why I get an error when running the executable and you do not!
Do you have a second machine to try it? I've tried the exe you attached in your last post in a clean virtual machine running Windows 10 x64 and it gives me the same result above.johnnix wrote: So could this be related to some sort of an OS problem? I cannot understand why I get an error when running the executable and you do not!
Today I upgraded to the latest Delphi 10.2 version, clean install, downloaded the latest Steema binary installer, got a few warnings at the end about GDIOBJ missing and the error still appears, cannot use the legend palette
Regarding the GDIPOBJ & GDIPAPI headers:
We can't fix a bug that hasn't been reproduced and identified.johnnix wrote:Today I upgraded to the latest Delphi 10.2 version, clean install, downloaded the latest Steema binary installer, got a few warnings at the end about GDIOBJ missing and the error still appears, cannot use the legend palette
ATTENTION: For those users with problems with missing GDIPOBJ & GDIPAPI headers, you can download them here.
This error does not go away after many years, fresh installation of Delphi Rio and still cannot use it!
- 2018-12-09_10-27-05.png (186.26 KiB) Viewed 38260 times
This looks as the continuation to this thread:
viewtopic.php?f=3&t=16547&p=74219#p74219
where we weren't able to reproduce the problem you are reporting.
I've just tried it using RAD 10.2.3 Tokyo + TeeChart v2018.25 without being able to reproduce any problem.
I'll give a try at the new TeeChart v2018.26 both with RAD 10.2.3 Tokyo and RAD 10.3 Rio and let you know.
The Legend Palette Tool seems to work without issues using TeeChart Pro v2018.26 in RAD 10.2.3 Tokyo and RAD 10.3 Rio here.
