Bars overlap
MVB
Bars overlap
Post by MVB » Tue Sep 04, 2012 12:25 pm
When I set the min and max values of my bottom axis, my bars start to overlap as shown in the screenshot attached.
The code I use is the following:
chartToTest.Aspect.View3D = false;
chartToTest.Axes.Bottom.Automatic = false;
chartToTest.Axes.Bottom.Minimum = 0;
chartToTest.Axes.Bottom.Maximum = 10;
Steema.TeeChart.Styles.Bar bar = new Steema.TeeChart.Styles.Bar(chartToTest.Chart);
bar.Add(1, 1000);
bar.Add(2, 1200);
bar.Add(3, 900);
bar.Add(4, 800);
What can I do to make the bars fit next to each other.
Marijke.
Re: Bars overlap
Post by Sandra » Wed Sep 05, 2012 8:29 am
Hello MVB,
We have considered your problem as a feature request with number [TF02016328] to be consider its inclusion in upcoming versions of TeeChartFor.Net. At the moment, a workaround to solve the problem you can change the BarWidthPercent to resize the bars. You can do something as next:
            tChart1.Axes.Bottom.Automatic = false;
            tChart1.Axes.Bottom.Minimum = 0;
            tChart1.Axes.Bottom.Maximum = 10;
            Steema.TeeChart.Styles.Bar bar = new Steema.TeeChart.Styles.Bar(tChart1.Chart);
            bar.Add(1, 1000);
            bar.Add(2, 1200);
            bar.Add(3, 900);
            bar.Add(4, 800);
            bar.BarWidthPercent = 25;
I hope will helps.
OMP
Re: Bars overlap
Post by OMP » Fri May 24, 2013 9:58 am
Hi Sandra,
The BarWidthPercent is indeed a workaround, but in our user interface we do not want a user to configure a certain percentage, and we cannot derive a percentage value which fits for all charts.
When is a solution for the Feature Request with number [TF02016328] planned?
Marijke.
Re: Bars overlap
Post by Sandra » Fri May 24, 2013 12:18 pm
Hello Marijke.
I have increased this severity of feature request number [TF02016328] to try consider it inclusion to upcoming versions of TeeChartFor.Net. On the other hand, I inform you that the time we need to fix the bugs depends on any variables such as the complexity of the problem, the number of issues with even higher priority that claims our team attention. For this reason, i recommend you to be aware at this forum, our RSS news feed, twitter and facebook accounts for new release announcements and what's implemented on them.
DEV1
Re: Bars overlap
Post by DEV1 » Fri Sep 09, 2016 1:28 am
Is this issue resolved? I have the same problem.
Re: Bars overlap
Post by Christopher » Mon Sep 12, 2016 12:01 pm
DEV1 wrote:Is this issue resolved? I have the same problem.
No, this issue is still existent, unfortunately. We will look to resolve it before the next maintenance release, due out before the end of this month.
PidoTech
Re: Bars overlap
Post by PidoTech » Thu Jan 26, 2017 5:49 am
Is this issue fixed already?
Re: Bars overlap
Post by Christopher » Thu Jan 26, 2017 2:42 pm
PidoTech wrote:Is this issue fixed already?
Yes, this one is fixed too:
