Tooltip traversing with mouse pointer.
SenSeo
Post by SenSeo » Tue May 31, 2016 12:20 pm
In my graph, I am using tooltip to display the details. The problem is, during the tooltip visible I am scrolling the mouse, at that time tooltip is traversing with the mouse pointer throughout the page.
Below is my code to display the tooltip,
                    var tip = new Tee.ToolTip(Chart1);
                    tip.render = "dom";
                    tip.autoHide = false;
                    tip.domStyle = "padding-left:8px; padding-right:8px; padding-top:0px; padding-bottom:4px; margin-left:5px; margin-top:0px; ";
                    tip.domStyle = tip.domStyle + "background-color:#FCFCFC; border-radius:4px 4px; color:#FFF; ";
                    tip.domStyle = tip.domStyle + "border-style:solid;border-color:#A3A3AF;border-width:3; z-index:1000;";
                    Chart1.tools.add(tip);
                    //tip.onhide = function () { scaling = 0; poindex = -1; }
                    tip.ongettext = function (tool, text, series, index) {
                        var toolTipValues = ["abc","xyz"];
                        var s = '<font face="verdana" color="blue" size="1">' + toolTipValues[index] + '</font>';
                        return s;
Can you please assist me to fix the tooltip traversing issue?
Re: Tooltip traversing with mouse pointer.
Post by Yeray » Wed Jun 01, 2016 9:12 am
Is this what you mean?
SenSeo
Post by SenSeo » Wed Jun 01, 2016 10:13 am
Yes correct.
SenSeo
Post by SenSeo » Wed Jun 01, 2016 10:17 am
Not only for mouse pointer move... It is happening for scroll too.
Post by Yeray » Wed Jun 01, 2016 1:23 pm
http://bugs.teechart.net/show_bug.cgi?id=1552
I've also fixed it for the next maintenance release.
Here the patch:
 teechart.js | 12 +++++++++++-
 1 file changed, 11 insertions(+), 1 deletion(-)
diff --git a/teechart.js b/teechart.js
index 018c879..65d542a 100644
--- a/teechart.js
+++ b/teechart.js
@@ -5886,7 +5886,13 @@ Tee.Chart=function(canvas,data,type)
     var c=this.chart;
-    if (!c.zoom.wheel.enabled) return;
+    if (!c.zoom.wheel.enabled) {
+      for(var t=0, s; s=c.tools.items[t++];)
+        if ((s instanceof Tee.ToolTip) && (s.active))
+          s.hide();
+      return;
     event=event || window.event;
@@ -5908,6 +5914,10 @@ Tee.Chart=function(canvas,data,type)
         if (event.preventDefault)
            event.preventDefault();
+          s.mousemove(p);
SenSeo
Post by SenSeo » Thu Jun 02, 2016 6:18 am
Great to hear that you have fixed this issue.
We are in the final stage of the development and we are yet to release the teechart graphs to our production as sooner. So, please share the Teechart.js library with the fix to us. It would be very helpful to us to fix this tooltip issue.
Thanks in advance!
Post by Yeray » Thu Jun 02, 2016 7:50 am
The patch in my last post should be enough to apply the fix in your version of the teechart.js (removing the lines starting with a "-" sign, and adding the lines starting with a "+" sign).
I'll send you a mail with the complete teechart.js anyway.
SenSeo
Post by SenSeo » Thu Jun 02, 2016 1:14 pm
Thanks!
I already tried to apply the patch fix to my teechart version. Unfortunately I was unsuccessful.
SenSeo
Post by SenSeo » Thu Jun 02, 2016 2:00 pm
We received the mail from you. But, it seems the attachment has been removed. Can you please share the "Teechart.js"CDN link to us?
Thanks!
Post by Yeray » Thu Jun 02, 2016 2:25 pm
SenSeo wrote:We received the mail from you. But, it seems the attachment has been removed. Can you please share the "Teechart.js"CDN link to us?
I've just sent you a new mail.
SenSeo
Post by SenSeo » Tue Jun 07, 2016 8:32 am
Still we are facing the tooltip traversing issue in some scenarios. If the series data values contains N no. of records, traversing issue is happening. This is not happening for the minimum amount of data's. Any insights?
Post by Yeray » Tue Jun 07, 2016 12:04 pm
I'm not able to reproduce the problem. Could you please arrange a simple example project/video we can run as-is to reproduce the problem here?
SenSeo
Post by SenSeo » Wed Jun 08, 2016 8:30 am
Below is my sample code which is having huge amount of data's.
<!DOCTYPE html>
<html>
<head>
    <title>TeeChart JavaScript Tooltips Example</title>
    <link type="text/css" href="../../jquery/css/ui-lightness/jquery-ui-1.8.17.custom.css" rel="Stylesheet" />
    <script type="text/javascript" src="../../jquery/js/jquery-1.7.1.min.js"></script>
    <script type="text/javascript" src="../../jquery/js/jquery-ui-1.8.17.custom.min.js"></script>
    <!--[if lt IE 9]>
    <![endif]-->
    <script src="Scripts/TeeChart/teechart.js"></script>
    <script src="Scripts/TeeChart/teechart-extras.js"></script>
    <script src="Scripts/TeeChart/teechart-animations.js"></script>
    <script src="Scripts/TeeChart/date.format.js"></script>
var Chart1, tip, scaling=0, poindex=-1;
function draw() {
    Chart1 = new Tee.Chart("canvas");
    var pointXY=new Tee.PointXY([355, 350, 346, 339, 332, 327, 320, 314, 305, 299, 291, 284, 278, 275, 269, 264, 262, 259, 257, 258,
      258, 259, 261, 263, 265, 266, 270, 271, 273, 276, 279, 268, 267, 268, 267, 266, 265, 262, 256, 252, 244, 238, 229, 220, 210, 200,
      191, 182, 172, 163, 154, 143, 135, 127, 120, 114, 108, 104, 101, 97, 96, 94, 95, 95, 96, 98, 101, 105, 110, 115, 122, 128, 137, 145,
      153, 163, 172, 183, 194, 206, 217, 228, 239, 250, 259, 270, 279, 289, 296, 304, 311, 316, 322, 325, 328, 331, 333, 332, 330, 329, 355,
      350, 346, 339, 332, 327, 320, 314, 305, 299, 291, 284, 278, 275, 269, 264, 262, 259, 257, 258, 258, 259, 261, 263, 265, 266, 270, 271, 273,
      276, 279, 268, 267, 268, 267, 266, 265, 262, 256, 252, 244, 238, 229, 220, 210, 200, 191, 182, 172, 163, 154, 143, 135, 127, 120, 114, 108,
      104, 101, 97, 96, 94, 95, 95, 96, 98, 101, 105, 110, 115, 122, 128, 137, 145, 153, 163, 172, 183, 194, 206, 217, 228, 239, 250, 259, 270,
      279, 289, 296, 304, 311, 316, 322, 325, 328, 331, 333, 332, 330, 329, 355, 350, 346, 339, 332, 327, 320, 314, 305, 299, 291, 284, 278, 275,
      269, 264, 262, 259, 257, 258, 258, 259, 261, 263, 265, 266, 270, 271, 273, 276, 279, 268, 267, 268, 267, 266, 265, 262, 256, 252, 244, 238,
      229, 220, 210, 200, 191, 182, 172, 163, 154, 143, 135, 127, 120, 114, 108, 104, 101, 97, 96, 94, 95, 95, 96, 98, 101, 105, 110, 115, 122, 128,
      137, 145, 153, 163, 172, 183, 194, 206, 217, 228, 239, 250, 259, 270, 279, 289, 296, 304, 311, 316, 322, 325, 328, 331, 333, 332, 330, 329, 355,
      350, 346, 339, 332, 327, 320, 314, 305, 299, 291, 284, 278, 275, 269, 264, 262, 259, 257, 258, 258, 259, 261, 263, 265, 266, 270, 271, 273, 276,
      279, 268, 267, 268, 267, 266, 265, 262, 256, 252, 244, 238, 229, 220, 210, 200, 191, 182, 172, 163, 154, 143, 135, 127, 120, 114, 108, 104, 101,
      97, 96, 94, 95, 95, 96, 98, 101, 105, 110, 115, 122, 128, 137, 145, 153, 163, 172, 183, 194, 206, 217, 228, 239, 250, 259, 270, 279, 289, 296, 304,
      311, 316, 322, 325, 328, 331, 333, 332, 330, 329, 355, 350, 346, 339, 332, 327, 320, 314, 305, 299, 291, 284, 278, 275, 269, 264, 262, 259, 257, 258,
      258, 259, 261, 263, 265, 266, 270, 271, 273, 276, 279, 268, 267, 268, 267, 266, 265, 262, 256, 252, 244, 238, 229, 220, 210, 200, 191, 182, 172, 163,
      154, 143, 135, 127, 120, 114, 108, 104, 101, 97, 96, 94, 95, 95, 96, 98, 101, 105, 110, 115, 122, 128, 137, 145, 153, 163, 172, 183, 194, 206, 217, 228,
      239, 250, 259, 270, 279, 289, 296, 304, 311, 316, 322, 325, 328, 331, 333, 332, 330, 329, 355, 350, 346, 339, 332, 327, 320, 314, 305, 299, 291, 284, 278,
      275, 269, 264, 262, 259, 257, 258, 258, 259, 261, 263, 265, 266, 270, 271, 273, 276, 279, 268, 267, 268, 267, 266, 265, 262, 256, 252, 244, 238, 229, 220,
      210, 200, 191, 182, 172, 163, 154, 143, 135, 127, 120, 114, 108, 104, 101, 97, 96, 94, 95, 95, 96, 98, 101, 105, 110, 115, 122, 128, 137, 145, 153, 163,
      172, 183, 194, 206, 217, 228, 239, 250, 259, 270, 279, 289, 296, 304, 311, 316, 322, 325, 328, 331, 333, 332, 330, 329, 355, 350, 346, 339, 332, 327, 320,
      314, 305, 299, 291, 284, 278, 275, 269, 264, 262, 259, 257, 258, 258, 259, 261, 263, 265, 266, 270, 271, 273, 276, 279, 268, 267, 268, 267, 266, 265, 262,
      256, 252, 244, 238, 229, 220, 210, 200, 191, 182, 172, 163, 154, 143, 135, 127, 120, 114, 108, 104, 101, 97, 96, 94, 95, 95, 96, 98, 101, 105, 110, 115,
      122, 128, 137, 145, 153, 163, 172, 183, 194, 206, 217, 228, 239, 250, 259, 270, 279, 289, 296, 304, 311, 316, 322, 325, 328, 331, 333, 332, 330, 329, 355,
      350, 346, 339, 332, 327, 320, 314, 305, 299, 291, 284, 278, 275, 269, 264, 262, 259, 257, 258, 258, 259, 261, 263, 265, 266, 270, 271, 273, 276, 279, 268,
      267, 268, 267, 266, 265, 262, 256, 252, 244, 238, 229, 220, 210, 200, 191, 182, 172, 163, 154, 143, 135, 127, 120, 114, 108, 104, 101, 97, 96, 94, 95, 95,
      96, 98, 101, 105, 110, 115, 122, 128, 137, 145, 153, 163, 172, 183, 194, 206, 217, 228, 239, 250, 259, 270, 279, 289, 296, 304, 311, 316, 322, 325, 328,
      331, 333, 332, 330, 329, 355, 350, 346, 339, 332, 327, 320, 314, 305, 299, 291, 284, 278, 275, 269, 264, 262, 259, 257, 258, 258, 259, 261, 263, 265, 266,
      270, 271, 273, 276, 279, 268, 267, 268, 267, 266, 265, 262, 256, 252, 244, 238, 229, 220, 210, 200, 191, 182, 172, 163, 154, 143, 135, 127, 120, 114, 108,
      104, 101, 97, 96, 94, 95, 95, 96, 98, 101, 105, 110, 115, 122, 128, 137, 145, 153, 163, 172, 183, 194, 206, 217, 228, 239, 250, 259, 270, 279, 289, 296,
      304, 311, 316, 322, 325, 328, 331, 333, 332, 330, 329, 355, 350, 346, 339, 332, 327, 320, 314, 305, 299, 291, 284, 278, 275, 269, 264, 262, 259, 257, 258,
      258, 259, 261, 263, 265, 266, 270, 271, 273, 276, 279, 268, 267, 268, 267, 266, 265, 262, 256, 252, 244, 238, 229, 220, 210, 200, 191, 182, 172, 163, 154,
      143, 135, 127, 120, 114, 108, 104, 101, 97, 96, 94, 95, 95, 96, 98, 101, 105, 110, 115, 122, 128, 137, 145, 153, 163, 172, 183, 194, 206, 217, 228, 239,
      250, 259, 270, 279, 289, 296, 304, 311, 316, 322, 325, 328, 331, 333, 332, 330, 329, 355, 350, 346, 339, 332, 327, 320, 314, 305, 299, 291, 284, 278, 275,
      269, 264, 262, 259, 257, 258, 258, 259, 261, 263, 265, 266, 270, 271, 273, 276, 279, 268, 267, 268, 267, 266, 265, 262, 256, 252, 244, 238, 229, 220, 210,
      200, 191, 182, 172, 163, 154, 143, 135, 127, 120, 114, 108, 104, 101, 97, 96, 94, 95, 95, 96, 98, 101, 105, 110, 115, 122, 128, 137, 145, 153, 163, 172,
      183, 194, 206, 217, 228, 239, 250, 259, 270, 279, 289, 296, 304, 311, 316, 322, 325, 328, 331, 333, 332, 330, 329, 355, 350, 346, 339, 332, 327, 320, 314,
      305, 299, 291, 284, 278, 275, 269, 264, 262, 259, 257, 258, 258, 259, 261, 263, 265, 266, 270, 271, 273, 276, 279, 268, 267, 268, 267, 266, 265, 262, 256,
      252, 244, 238, 229, 220, 210, 200, 191, 182, 172, 163, 154, 143, 135, 127, 120, 114, 108, 104, 101, 97, 96, 94, 95, 95, 96, 98, 101, 105, 110, 115, 122,
      128, 137, 145, 153, 163, 172, 183, 194, 206, 217, 228, 239, 250, 259, 270, 279, 289, 296, 304, 311, 316, 322, 325, 328, 331, 333, 332, 330, 329, 355, 350,
      346, 339, 332, 327, 320, 314, 305, 299, 291, 284, 278, 275, 269, 264, 262, 259, 257, 258, 258, 259, 261, 263, 265, 266, 270, 271, 273, 276, 279, 268, 267,
      268, 267, 266, 265, 262, 256, 252, 244, 238, 229, 220, 210, 200, 191, 182, 172, 163, 154, 143, 135, 127, 120, 114, 108, 104, 101, 97, 96, 94, 95, 95, 96,
      98, 101, 105, 110, 115, 122, 128, 137, 145, 153, 163, 172, 183, 194, 206, 217, 228, 239, 250, 259, 270, 279, 289, 296, 304, 311, 316, 322, 325, 328, 331,
      333, 332, 330, 329, 355, 350, 346, 339, 332, 327, 320, 314, 305, 299, 291, 284, 278, 275, 269, 264, 262, 259, 257, 258, 258, 259, 261, 263, 265, 266, 270,
      271, 273, 276, 279, 268, 267, 268, 267, 266, 265, 262, 256, 252, 244, 238, 229, 220, 210, 200, 191, 182, 172, 163, 154, 143, 135, 127, 120, 114, 108, 104,
      101, 97, 96, 94, 95, 95, 96, 98, 101, 105, 110, 115, 122, 128, 137, 145, 153, 163, 172, 183, 194, 206, 217, 228, 239, 250, 259, 270, 279, 289, 296, 304,
      311, 316, 322, 325, 328, 331, 333, 332, 330, 329, 355, 350, 346, 339, 332, 327, 320, 314, 305, 299, 291, 284, 278, 275, 269, 264, 262, 259, 257, 258, 258,
      259, 261, 263, 265, 266, 270, 271, 273, 276, 279, 268, 267, 268, 267, 266, 265, 262, 256, 252, 244, 238, 229, 220, 210, 200, 191, 182, 172, 163, 154, 143,
      135, 127, 120, 114, 108, 104, 101, 97, 96, 94, 95, 95, 96, 98, 101, 105, 110, 115, 122, 128, 137, 145, 153, 163, 172, 183, 194, 206, 217, 228, 239, 250,
      259, 270, 279, 289, 296, 304, 311, 316, 322, 325, 328, 331, 333, 332, 330, 329, 355, 350, 346, 339, 332, 327, 320, 314, 305, 299, 291, 284, 278, 275, 269,
      264, 262, 259, 257, 258, 258, 259, 261, 263, 265, 266, 270, 271, 273, 276, 279, 268, 267, 268, 267, 266, 265, 262, 256, 252, 244, 238, 229, 220, 210, 200,
      191, 182, 172, 163, 154, 143, 135, 127, 120, 114, 108, 104, 101, 97, 96, 94, 95, 95, 96, 98, 101, 105, 110, 115, 122, 128, 137, 145, 153, 163, 172, 183,
      194, 206, 217, 228, 239, 250, 259, 270, 279, 289, 296, 304, 311, 316, 322, 325, 328, 331, 333, 332, 330, 329, 355, 350, 346, 339, 332, 327, 320, 314, 305,
      299, 291, 284, 278, 275, 269, 264, 262, 259, 257, 258, 258, 259, 261, 263, 265, 266, 270, 271, 273, 276, 279, 268, 267, 268, 267, 266, 265, 262, 256, 252,
      244, 238, 229, 220, 210, 200, 191, 182, 172, 163, 154, 143, 135, 127, 120, 114, 108, 104, 101, 97, 96, 94, 95, 95, 96, 98, 101, 105, 110, 115, 122, 128,
      137, 145, 153, 163, 172, 183, 194, 206, 217, 228, 239, 250, 259, 270, 279, 289]);
    pointXY.format.stroke.size = 4;
    pointXY.pointer.style = "ellipse";
    pointXY.pointer.width = 5;
    pointXY.pointer.height = 5;
    Chart1.addSeries(pointXY);
    Chart1.axes.left.setMinMax(80, 360);
  Chart1.axes.left.format.stroke.fill = "green";
  Chart1.axes.left.title.text="Left Axis";
  Chart1.axes.bottom.title.text="Bottom Axis";
  Chart1.title.text="Mouse-over Tooltips";
  Chart1.title.format.font.style="18px Verdana";
  Chart1.series.items[0].format.stroke.fill="darkorange";
  Chart1.series.items[0].pointer.visible=true;
  Chart1.panel.format.stroke.fill="";
  Chart1.panel.format.shadow.visible=true;
  tip=new Tee.ToolTip(Chart1);
  tip.render = "dom";
  tip.domStyle = "padding-left:8px; padding-right:8px; padding-top:0px; padding-bottom:4px; margin-left:5px; margin-top:0px;";
  tip.ongettext = function (tool, text) { return '<font face="verdana" color="blue" size="1">' + "Text:\n" + text + '</font>'; }
  Chart1.legend.visible = false;
  Chart1.draw();
    </script>
</head>
<body onload="draw()">
    <br />
    <br />
    <br />
    <br />
    <br />
    <br />
    <canvas id="canvas" width="1200" height="800">
    </canvas>
</body>
</html>
In some scenarios the traversing issue is happening.
Post by Yeray » Thu Jun 09, 2016 11:12 am
As an extra check, you can use the body's mousemove event and hide the ToolTip if the mouse is out of the chart canvas:
            var canvas = document.getElementById('canvas');
            var body = document.body;
            body.addEventListener('mousemove', function(evt) {
                var rect = canvas.getBoundingClientRect();
                if ((evt.clientX < rect.left) || (evt.clientX > rect.right) || (evt.clientY < rect.top) || (evt.clientY > rect.bottom)) {
                    tip.hide();
            }, false);
SenSeo
Post by SenSeo » Wed Jun 22, 2016 5:20 am
This solution is not working for me. I am having more than 4 pages and each page contains the tee chart graph with tooltip display. If I go with the body's mousemove event, it is working only for one page. For the remaining pages tooltip is not displaying. Is there any other solution available to fix this issue?
