I would like to display some text on left top corner in tee chart. Can anyone help me how to do this. As shown in the image below.
How to display some text in Tee chart.
- image.jpg (17.98 KiB) Viewed 15872 times
Re: How to display some text in Tee chart.
Hello bijit,
I think you can use annotation tool to add the titles let-top corner as do in next lines of code:
Could you confirm us if previous code works in your end?
I hope will helps.
private void AddTitles()
tChart1.Draw();
//Create Annotations
anSeries1 = new Steema.TeeChart.Tools.Annotation(tChart1.Chart);
//First Title
anSeries1.Text = "Hello";
anSeries1.Shape.Font.Color = Color.Black;
anSeries1.Shape.Font.Bold = true;
//position
anSeries1.Left = rect.Left;
anSeries1.Top = tChart1.Axes.Right.IStartPos;
anSeries1.Shape.Pen.Visible = false;
anSeries1.Shape.Shadow.Visible = false;
anSeries1.Shape.Brush.Transparency = 100;
I hope will helps.
Hi sandra,
Thanks for your help. it works well.
regards,
biji
regards,
biji
Hi Sandra,
The above code working well to display some text on teechart.
I have a small problem here, how to refresh the text because I have written one text first and when i load another chart data then it has to replace the old text with new text but what happening with the above code is it it was not replacing but it was overwriting the old text. Both text's are displaying at the same place.
could you tel me how to refresh or replace the old text with new?
I have tried withbut still i have same problem.
biji.
I have tried with
tChart1.Refresh();
biji.
- Guru
Hello Biji,
Maybe when you load another chart data you are creating two annotation tools, one of which is on top of the other. You could check if you already have an Annotation on the chart by code like this (press the button twice):
if this is not the problem you have, could you please add a little code to your reply so I can reproduce the problem here?
Thank you,
Christopher Ireland.
Annotation anSeries1;
if (anSeries1 == null)
//First Title
//position
anSeries1.Left = 100;
anSeries1.Text = "New Hello";
Thank you,
Hi Christopher,
yes, your guess was correct. I was creating two annotation tools, but i thought when you refresh chart it will disappear. Now i have used your logic, it works well.
Thanks allot.
biji.
Thanks allot.
biji.
- Guru
Hello Biji,
You're very welcome.
_/|\_
_/|\_
