i have a problem with the last column width in bars series.
all the other bars are in the same size and the last bar gets a different size.
in addition, when i have two groups of data with some space between, the last bar of the first group resize and stretch to join the first bar of the second group.
see attached screenshots.
i tried to change offsetPercent and BarWidthPercent but i couldn't solve it. i don't want to set CustomBarWidth because i will lose the ability of the teechart to change the bar size as a function of the size.
i just want that the last bar will be in the same size of the others.
what can i do?
Last column width
Last column width
- tchart2.JPG (21.31 KiB) Viewed 14783 times
- tchart1.JPG (23.35 KiB) Viewed 14732 times
Re: Last column width
Hello MShefi,
I recommend take a look in the Demo project, concretely in this sample All Features\Welcome !\Chart styles\Standard\Bar\Bar Size example that I think allow you achieve as you want.
i saw the example in the demo, but i can't find "SizeValues" property in my series.
In addition, it seems like something in the axes change.
see axes differences in attached pictures.
Hello Mshefi,
Can you please send us a simple example because we can reproduce your problem here and try to find a good solution for you?
Hi Sandra,
it is very problematic to copy the code. it's complex, we do initiation and configuration on several places,etc.
Update:
i fixed the big bar problem with TeeChart.Page.MaxPointsPerPage.
Hello MShefi,
Sorry for the delay. I have made a simple project where I using a custom Bar Series to achieve as you want.
Can you tell us if attached project works as you want?
