Some queries on the attached Pie Charrt:-
On the numbers around the graph, require no box and the font to bigger
How do I force the order, We need the white to be top and then clockwise with the others
Pie Charts
Pie Charts
- RAL_488_Ethnic.jpg (43.48 KiB) Viewed 13450 times
Re: Pie Charts
Hello MiketheLad,
I suggest you define the position of your values when you add it in the series, as do in next example of code:
Can you tell us if previous code helps you to solve your problem?
Steema.TeeChart.Styles.Pie Series1;
Series1 = new Steema.TeeChart.Styles.Pie(tChart1.Chart);
Series1.Add(74);
Series1.Add(6);
Series1.Add(5);
Series1.Add(8);
Series1.Add(4);
Series1.Marks.Style = Steema.TeeChart.Styles.MarksStyles.Percent;
Re: Pie Charts
I have treid changing the order, but seem unable to get the white to be at the top, also what about the box and font size of the labels next to the pie
Steema.TeeChart.TChart tChart2 = new Steema.TeeChart.TChart();
Steema.TeeChart.Styles.Pie pie = new Steema.TeeChart.Styles.Pie(tChart2.Chart);
tChart2.Legend.Visible = false;
tChart2.Header.Text = "";
tChart2.Chart.Panel.Color = System.Drawing.Color.White;
tChart2.Chart.Panel.Visible = false;
tChart2.Chart.Walls.Visible = false;
tChart2.Chart.Panel.Bevel.Outer = Steema.TeeChart.Drawing.BevelStyles.None;
tChart2.Chart.Panel.Bevel.Inner = Steema.TeeChart.Drawing.BevelStyles.None;
tChart2.Aspect.View3D = false;
pie.Add(Convert.ToInt32(ethnicperc1), ethnicperc1 + "%", Color.FromArgb(49, 151, 101));
pie.Add(Convert.ToInt32(ethnicperc3), ethnicperc3 + "%", Color.FromArgb(245, 152, 31));
pie.Add(Convert.ToInt32(ethnicperc4), ethnicperc4 + "%", Color.FromArgb(205, 205, 205));
pie.Add(Convert.ToInt32(ethnicperc5), ethnicperc5 + "%", Color.FromArgb(244, 243, 160));
pie.Add(Convert.ToInt32(ethnicperc6), ethnicperc6 + "%", Color.FromArgb(157, 197, 233));
pie.Add(Convert.ToInt32(ethnicperc2), ethnicperc2 + "%", Color.FromArgb(255, 255, 255));
Re: Pie Charts
Hello MikeTheLad,
Using last version of TeeChart2011 and next code:
I have gotten next results:
Can you try again run previous code and tell us if you can get a good results? On the other hand, If you doesn't use last version of TeeChartFor.Net, please tell us which version are you using now.
And I have gotten next results:
Can you tell us, if previous lines of code works as you expected?
Steema.TeeChart.Styles.Pie pie = new Steema.TeeChart.Styles.Pie(tChart1.Chart);
tChart1.Header.Text = "";
pie.Circled = true;
tChart1.Chart.Panel.Color = System.Drawing.Color.White;
tChart1.Chart.Panel.Bevel.Outer = Steema.TeeChart.Drawing.BevelStyles.None;
tChart1.Chart.Panel.Bevel.Inner = Steema.TeeChart.Drawing.BevelStyles.None;
Random rnd = new Random();
int ethnicperc1, ethnicperc2, ethnicperc3,ethnicperc4, ethnicperc5, ethnicperc6;
ethnicperc1 = 74;
ethnicperc2 = 4;
ethnicperc3 = 6;
ethnicperc4 = 2;
ethnicperc5 = 5;
ethnicperc6 = 8;
pie.Add(ethnicperc1, ethnicperc1.ToString() + "%", Color.FromArgb(49, 151, 101));
pie.Add(ethnicperc3, ethnicperc3.ToString() + "%", Color.FromArgb(245, 152, 31));
pie.Add(ethnicperc4, ethnicperc4.ToString() + "%", Color.FromArgb(205, 205, 205));
pie.Add(ethnicperc5, ethnicperc5.ToString() + "%", Color.FromArgb(244, 243, 160));
pie.Add(ethnicperc6, ethnicperc6.ToString() + "%", Color.FromArgb(157, 197, 233));
pie.Add(ethnicperc2, ethnicperc2.ToString() + "%", Color.FromArgb(255, 255, 255));
Sorry I forgot answer this question. If you want as the boxs of Marks don't appear and font of Marks is to bigger, you need use next properties of Marks to modify their aspect:On the numbers around the graph, require no box and the font to bigger
- - Series.Marks.Pen.Visible = False or True;
- Series.Marks.Color.Transparency= 100. You have indicate the % of transparency you want to marks. And also you can use Series.Marks.Transparent = true; where you indicate as if you want Mark transparent or not.
- Series.Marks.Font.Size = 12. To Change the size of font.
//Marks;
pie.Marks.Transparent = true;
pie.Marks.Transparency = 100;
pie.Marks.Pen.Visible = false;
pie.Marks.Arrow.Visible = false;
pie.Marks.Font.Size = 12;
Re: Pie Charts
We need the graph rotating around 90 degress, sample attached of what I am trying to produce
- Graph Sample.jpg (26.9 KiB) Viewed 13346 times
Re: Pie Charts
Hello MikeTheLad,
Series have a method that allow rotate the Series. To achieve as you want I recommend rotate your Series an angle of 180º as do in next line of code:
Can you tell us, if previous line works as you expected?
pie.Rotate(180);
Re: Pie Charts
Thanks, that is what I needed
