Chart colors
Chart colors
we are testing the new activeX version 2010. we currently use v7.
in v7 we designed the charts template to have certain colors. for example red and green.
when we use the new version 2010, there is a change in the colors (please see the attachments)
there are 2 attached files:
1. tee chart 7 - this contains the colors we designed - gradient red
2. tee chart 2010 - this contains how it looks using the new version (the colors are NOT looking OK)
why is that, and how can we solve it ?
10x
Ron
10x
Ron
- tee chart 2010
- 8.0_red.png (14.82 KiB) Viewed 23510 times
- tee chart 7
- 7.0_sp1_red.png (11.46 KiB) Viewed 23490 times
Re: Chart colors
Hello Oblicore,
I could reproduce your problem and I have added it in bug list report with number [TV52015384]. We will try to fix it for next maintenance releases of TeeChartVCL. On the other hand, for now you can assign the EndColor, changing default color of BarSeries as you want. For example, if you want EndColor=Blue you only must assign Bar.Color= Blue as do in next example:
I hope will helps.
TChart1.AddSeries scBar
TChart1.Series(0).Color = vbBlue
TChart1.Series(0).asBar.Gradient.Visible = True
TChart1.Series(0).asBar.BarStyle = bsRectGradient
TChart1.Series(0).asBar.Gradient.StartColor = vbRed
TChart1.Series(0).asBar.Gradient.MidColor = vbWhite
TChart1.Series(0).FillSampleValues (2)
Re: Chart colors
thanks for the quick response.
3 questions:
1. can you tell me when is your next release?
2. can you tell me if that will be in the next release?
3. will you be able to supply us a hot fix for that? this is a very crucial thing for us
10x
3 questions:
10x
Re: Chart colors
Hello Ron,
I recommend you to be aware at this forum, our RSS news feed, twitter and facebook accounts for new release announcements and what's fixed on them.
You can use for now our suggestion of workaround, assign Series.Color the color are you want as Gradient EndColor, how do in the previous example code I have posted.3. will you be able to supply us a hot fix for that? this is a very crucial thing for us
Re: Chart colors
Are you kidding me? (twitter?)
why should I use twitter\facebook for that? can't you tell me when and if it is planned to be fixed?
if this cannot be fixed in a time that suits us, we will go to the workaround, even though it is a big problem!!!
10x
Ron
10x
Ron
Re: Chart colors
Hello Ron,
We use twitter, facebook and Rss new feed, for publish the announcements of new maintenance releases of TeeChart Versions, so clients are informed the day of the new versions are posted in page download.Are you kidding me? (twitter?)
We have increased the severity of bug (TV52015384), but we can not tell the exactly date are fixed it at the moment.can't you tell me when and if it is planned to be fixed?
Re: Chart colors
Hello Ron,
I have communicated that bug (TV52015384) is not a bug. In version of TeeChartActivex 2010 we change the default themes, so the Gradient looks different. If you want get the same result that you had in version 7 you only change the theme of Chart for Default TeeChart as do in next example:
I hope will helps.
TChart1.SetTheme ctDefault, cpTeeChart
Re: Chart colors
OK
we will check this
10x for the quick response
Ron
we will check this
Ron
Re: Chart colors
Before we start changing our code, please provide some information on exactly when we need to add the “SetTheme” method call.
For example:
After each time we call the TChart constructor call?
After every AddSeries call?
Additionally, when do we not need to call the SetTheme method?
For example:
If a chart is loaded from a Stream.
10x
Ron
For example:
For example:
10x
Ron
Re: Chart colors
Hello Ron,
As you can see in code, I set Theme in TChart2 before load stream, so it should be applied correctly.
I hope will helps.
You only need set theme one time, when you Initialize Chart as do in next example, but always that chart has be created previously:After each time we call the TChart constructor call?
You need call SetTheme to chart where you want loaded Stream, as do in next example:Additionally, when do we not need to call the SetTheme method?
For example:
Private MyStream As Variant
Private Sub Command1_Click()
TChart2.Import.LoadFromStream MyStream
Private Sub Command2_Click()
MyStream = TChart1.Export.asNative.SaveToStream(True)
TChart2.SetTheme ctDefault, cpTeeChart
I hope will helps.
Re: Chart colors
we tried to do what you said and using your code example, it doesn't seem to help, it seems that with that code and without it we get the same result.
can you please provide us another solution for this problem, did you manage to reproduce it in your labs? does the provided solution helps?
10x
Ron
10x
Ron
Re: Chart colors
Hello Ron,
The solution I have provided you works fine here. Please, could you send us a simple project we run "as-is" to reproduce problem here?
