Tennis single or double elimination diagram
Tom
Post by Tom » Mon Nov 15, 2004 7:31 pm
Would TeeTree be Ok to use to generate a single or double eliminiation diagram like you would see at a tennis tourniment?
Tom Berry
tom
Post by tom » Wed Nov 17, 2004 9:07 pm
Sorry, can you provide more information:
eg:
* picture
* the required functionalities.
tom
Tom
Post by Tom » Thu Nov 18, 2004 3:20 pm
When I try to make the diagram the editor takes out the spaces so it will not look like I want it to.
It is a typical single elimination diagram where two players play and the winner plays the winner of another match.
It has all the teams playing on the left side and the winner on the right side.
And I would like to be able to enter the names of the players as they advance in the tournment.
Any help?
Tom Berry
tom
Post by tom » Mon Nov 22, 2004 3:53 pm
1) Positioning:
Depending on which AlignChild you use, you can change the spaces between the nodes. eg in de TTreeLeftRightAlignChild manager, you can change the horizontal & vertical spaces by the following properties:
procedure TLeftRightAlignForm.ScrollBar2Change(Sender: TObject);
  SideAlign.VertMargin:=ScrollBar2.Position;
  Tree1.Invalidate;
procedure TLeftRightAlignForm.ScrollBar1Change(Sender: TObject);
  SideAlign.HorizMargin:=ScrollBar1.Position;
  Tree1.Invalidate;
If no alignmanager can provide the functionality you need, you can either, fix position the nodes (thus overuling the automatic positioning of the alignmanager) or create your own alignmanager descendant.
2) Editing
To change the names directly on the diagram, you've to set the node in editing mode:
Tree1.StartEditing(Node1);
Default the F2 key puts the selected node in editing mode as well.
More information can be found in the teeTree2 demo application:
Welcome > Nodes > Adding/Modifying
Welcome > Tree Features > Text Editor ReadOnly
Tom.[/code]
