I have only 1 series assigned to an axis and I do the following:
CAxis CurrentAxis;
double fAxisMin = CurrentAxis.MinVisibleSeriesValue(false,0);
double fAxisMax = CurrentAxis.MaxVisibleSeriesValue(false,0);
Should I not get the Minimum and Maximum of the series Y values? (Its the first series added to the chart, so the Series Number is 0). Instead I'm getting some very small number of the order of E-15.
Is there any method (that belongs to CAxis) that will give me the number of series currently associated with an axis?
MinVisibleSeriesValue & MaxVisibleSeriesValue
Hi nbp,
Maybe you don't need the MinVisibleSeriesValue method. You could try with the following:
If this doesn't work either, please, could you send us a simple example project we can run "as-is" to reproduce the problem here? You can either post your files at news://www.steema.net/steema.public.attachments newsgroup or at our upload page.
TChart1.Series(0).YValues.Minimum
TChart1.Series(0).YValues.Maximum
To do this, you should manually count the series linked to the custom axis. Something like this:nbp wrote:Is there any method (that belongs to CAxis) that will give me the number of series currently associated with an axis?
counter = 0
For i = 0 To TChart1.SeriesCount - 1
If TChart1.Series(i).VerticalAxisCustom = 0 Then
counter = counter + 1
End If
Next i
