TPolarBarSeries
Sean
TPolarBarSeries
Post by Sean » Tue Jun 08, 2004 4:09 pm
Hi, I'm trying to plot a PolarBarSeries of wave data which comprises of wave direction in degrees (the Angle) against wave height in meters (the Radius). The problem I have is that the directional component is being plotted anticlockwise even when I set the series labels to clockwise.
Is there any way to get the direction(Angle) to increment clockwise from north so that 0 deg is north, 90 deg it east, 180 is south and 270 is west.
Sean Palmer.
Pep
Post by Pep » Wed Jun 09, 2004 4:24 pm
Hi Sean,
you can do this :
Series1.CircleLabels := true;
Series1.ClockWiseLabels := true;
Series1.RotationAngle := 90;
Sean
Post by Sean » Thu Jun 10, 2004 10:25 am
Hi Pep,
That's exactly how I have the series parameters set already, the labels are displaying correctly but the data is still displaying the directions anti-clockwise.
If I plot an angle of 299 degrees and radius of 1.0 the PolatBarSeries visually plots the angle at 61 degrees.
Cheers,
Sean.
Marjan
Post by Marjan » Thu Jun 10, 2004 3:31 pm
Hi, Sean.
You can use series OnAfterAdd event to "transform" values from acw to cw. This involves the following operation:
angle = 360 - angle
Something like this:
procedure TForm1.Series1AfterAdd(Sender: TChartSeries;
  ValueIndex: Integer);
    Sender.XValue[ValueIndex] := 360 - Sender.XValue[ValueIndex];
Marjan Slatinek,
Sean
Post by Sean » Thu Jun 10, 2004 3:59 pm
Hi Marjan,
Thanks for that, I was basically doing the same but on a calculated field in the dataset.
The point that I think should be raised is that if Series1.ClockWiseLabels is set to true, then the dataset should automatically be converted from acw to cw.
Cheers,
Sean.
