I cannot seem to get data displayed correctly to a polar plot. Could you please provide an example of how this is accomplished, please do not use the "this.polar1.FillSampleValues(100)" command.
Thank you.
Sending data to polar plots
Hi, John.
First parameter in Add is associated with angle, second with radius. Hope this helps.
How about this:FillSampleValues(100)
polar1.Clear();
polar1.Add(10,200); // angle = 10deg, radius = 200
polar1.Add(45,110); // angle = 45deg, radius = 110
polar1.Add(210,250); // angle = 210deg, radius = 250
polar1.Add(340,220); // angle = 340deg, radius = 220
Marjan Slatinek,
Thank you very much. I was trying to put arrays into the polar plot via the add using the following commands:
this.polar1.Add(angValues, magValues);
where magValues and angValues are arrays that have been give their respective data points. Is there a method to put complete arrays in?
Thanks again for your quick response.
Hi John,
Yes, just as you did :points. Is there a method to put complete arrays in?
Pep Jorge
http://support.steema.com
This is what I understood for adding complete magnitude and angle arrays to the polar plot (this.polar1.Add(angValues, magValues);), but the polar plot does not seem to display the values. Is there some additional commands to make the polar plot display properly?
The following is a larger segment of my code:
this.polar1.Pen.Color = System.Drawing.Color.Cyan;
this.polar1.CirclePen.Visible =false;
this.polar1.ClockWiseLabels = false;
this.polar1.AngleIncrement = 10;
this.polar1.Chart.Axes.Visible = true;
this.polar1.Chart.Axes.Left.AxisPen.Visible = true;
this.polar1.Chart.Axes.Right.AxisPen.Visible = true;
this.polar1.Chart.Axes.Top.AxisPen.Visible = true;
this.polar1.Chart.Axes.Bottom.AxisPen.Visible = true;
this.polar1.Chart.Axes.Left.AxisPen.Width = 2;
this.polar1.Chart.Axes.Right.AxisPen.Width = 2;
this.polar1.Chart.Axes.Top.AxisPen.Width = 2;
this.polar1.Chart.Axes.Bottom.AxisPen.Width = 2;
this.polar1.Chart.Axes.Left.Labels.Visible = false;
this.polar1.Chart.Axes.Right.Labels.Visible = false;
this.polar1.Chart.Axes.Top.Labels.Visible = false;
this.polar1.Chart.Axes.Bottom.Labels.Visible = false;
double[] magValues = new double[10];
double[] angValues = new double[10];
magValues[0] = 150;
magValues[1] = 150;
magValues[2] = 150;
magValues[3] = 150;
magValues[4] = 150;
magValues[5] = 150;
magValues[6] = 150;
magValues[7] = 150;
magValues[8] = 150;
magValues[9] = 150;
angValues[0] = 45;
angValues[1] = 135;
angValues[2] = 225;
angValues[3] = 315;
angValues[4] = 135;
angValues[5] = 45;
angValues[6] = 225;
angValues[7] = 45;
angValues[8] = 315;
angValues[9] = 135;
this.polar1.RefreshSeries();
I have used tChart for the past ~2 years, but this is the first time that I have worked with the polar chart.
Thanks again for your help.
magValues[0] = 150;
magValues[1] = 150;
magValues[2] = 150;
magValues[3] = 150;
magValues[4] = 150;
magValues[5] = 150;
magValues[6] = 150;
magValues[7] = 150;
magValues[8] = 150;
magValues[9] = 150;
angValues[0] = 45;
angValues[1] = 135;
angValues[2] = 225;
angValues[3] = 315;
angValues[4] = 135;
angValues[5] = 45;
angValues[6] = 225;
angValues[7] = 45;
angValues[8] = 315;
angValues[9] = 135;
Hi John,
the problem is in the following line, sorry to not see this before (in your last post) :
that should be :
this.polar1.Add(magValues,angValues);
that should be :
Pep Jorge
Thanks!
Thanks you for the help, this worked. I also discovered that to scale a polar chart was not obvious, it took the following commands:
this.tChart1.Axes.Left.Maximum = maxValue;
this.tChart1.Axes.Left.Minimum = minValue;
The confusing part for me was that the Axes.Left perfoms the radius scaling, while the Axes.Bottom performs the angular scaling.
Thanks again for your quick response; have a great weekend!
