TTree redraw issues
Sebastian
TTree redraw issues
Post by Sebastian » Wed May 19, 2010 8:20 am
It seems TTree control doesn't get properly refreshed/repainted under some conditions. (see attachments)
It is most noticable after some of tree parameters were changed - first repaint doesn't happen as it should:
a) reposition tree nodes (TTreeNodeShape->X0=...), resize form which contains TTree control
b) change tree node shape, resize form
c) zoom, change tree node shape
Previously we were used rather old TeeTree2C6Tee6. Everything worked fine for this control.
Any help would be appreciated,
Thanks in advance,
Sebastian
Re: TTree redraw issues
Post by Yeray » Thu May 20, 2010 2:49 pm
Hi Sebastian,
Trying to reproduce it in a as simple example as possible, here is what I get:
1. Create a new application.
2. Drop a TTree in the form, not very big.
3. Double click the Tree to get into the editor. Add a big Rectangle (TTreeNodeShape) and close the editor:
4. Resize the Tree to try to see the whole NodeShape:
Sebastian
Post by Sebastian » Fri May 21, 2010 6:28 am
So it seems that you were able to easily reproduce it, right ?
The attached screenshot looks corrupted.
Post by Yeray » Fri May 21, 2010 9:27 am
Hi Sebastian,
Thank you.
I've added it to the defect list to be fixed in future releases (TV52014907).
Sebastian
Post by Sebastian » Fri Sep 17, 2010 12:41 pm
Any chances to include the fix in v2010.01 ?
Post by Yeray » Fri Sep 17, 2010 1:08 pm
Hi Sebastian,
I'm afraid it hasn't been fixed yet. I'll increment the priority to this ticket.
