Legend.Width
ctusch
Legend.Width
Post by ctusch » Tue May 27, 2008 2:12 pm
I want my legend to be of a fixed size so I set AutoSize to false. But always when I try to set the Width property it resets itself back to its old value. What am I doing wrong?
Post by Narcís » Tue May 27, 2008 2:59 pm
Hi ctusch,
Could you please send us a simple example project we can run "as-is" to reproduce the problem here?
ctusch
Post by ctusch » Wed May 28, 2008 10:00 am
Hi Narcis,
I wasn't able to reproduce my exact problem inside a demo app but another problem appeared there (I've uploaded the project): When I set Legend.AutoSize to false the legend won't display at all. I don't know if these two problems are related.
Post by Narcís » Wed May 28, 2008 10:35 am
Hi ctusch,
Thanks for the example project. I could reproduce the issue here and it's probable they are related. I've added the bug (TF02013088) to our defect lst to be fixed for next releases. In the meantime you can set custom legend position:
            Line line = new Line();
            this.tChart1.Series.Add(line);
            line.Add(1, 0);
            line.Add(2, 2);
            line.Add(3, 3);
            line.Add(4, 3);
						tChart1.Legend.AutoSize = false;
						tChart1.Panel.MarginRight = 20;
						tChart1.Legend.CustomPosition = true;
						Bitmap bmp = tChart1.Bitmap;
						Rectangle rect = tChart1.Chart.ChartRect;
						tChart1.Legend.Left = rect.Right + 10;
						tChart1.Legend.Top = rect.Top;
ctusch
Post by ctusch » Wed May 28, 2008 11:27 am
Alright, thanks!
ctusch
Post by ctusch » Wed May 28, 2008 12:26 pm
Narcis,
now I seem to experience the same problem as before. I changed the code of the sample project as you posted but I get bad results. I've uploaded you two screen shots, one after program startup and the other after rescaling the window. Aren't you experiencing the same problems?
Post by Narcís » Wed May 28, 2008 12:41 pm
Hi ctusch,
Yes, in that case you'll need to use AfterDraw and Resize events like this:
            line.Add(1, 0);
            line.Add(2, 2);
            line.Add(3, 3);
            line.Add(4, 3);
				private void tChart1_AfterDraw(object sender, Steema.TeeChart.Drawing.Graphics3D g)
				private void tChart1_Resize(object sender, EventArgs e)
ctusch
Post by ctusch » Wed May 28, 2008 1:40 pm
Narcis,
I was able to set the Legend.Width after calling tChart1.Bitmap. Now I'm still having the problem that the legend doesn't keep itself at a fixed distance from the right border. I've uploaded two screen shots for you again.
Post by Narcís » Wed May 28, 2008 2:45 pm
Hi ctusch,
In that case you can implement AfterDraw event like this:
					//tChart1.Legend.Left = tChart1.Width - 100;
					tChart1.Legend.Left = tChart1.Width - tChart1.Legend.Width;
Post by Narcís » Thu May 29, 2008 8:37 am
Hi ctusch,
As an update, a TeeChart for .NET developers pointed me out that he doesn't think TF02013088 is a bug. When you set AutoSize to false, you have to set the width and height manually. The following code works as expected:
			InitializeChart();
			Steema.TeeChart.Styles.Line line = new Steema.TeeChart.Styles.Line();
			line.Add(1, 0);
			line.Add(2, 2);
			line.Add(3, 3);
			line.Add(4, 3);
			tChart1.Legend.Width = 50;
			tChart1.Legend.Height = 100;
Post by Narcís » Thu May 29, 2008 8:39 am
Hi ctusch,
			InitializeChart();
			line.Add(1, 0);
			line.Add(2, 2);
			line.Add(3, 3);
			line.Add(4, 3);
