IOS bug for TeeChart. Xamarin.Forms
Post by 18286055 » Fri May 03, 2019 7:50 pm
"Chart.initVars ()" fails on IOS with a System.NullReferenceException. Android works without issue.
Either of "ChartView LineChart = new ChartView();" or "Chart1 = new Chart();" gives the error.
The license file is present for TeeChart.
Project is a .net standard 2.0 PCL Xamarin.Forms with both IOS and Android.
The code below is from the example "Nearest point tool" copied over to the new project:
using System;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using Xamarin.Forms;
using Steema.TeeChart;
using Steema.TeeChart.Styles;
using Steema.TeeChart.Tools;
namespace NearestPointTool
	public partial class MainPage : ContentPage
		public MainPage()
			/* Create ChartView by code at ContentPage */
			/* cursor movement buttons */
			Button bBack = new Button();
			Button bFwd = new Button();
			bFwd.Text = "forward";
			bBack.Text = "back";
			bBack.HeightRequest = 100;
			bFwd.HeightRequest = 100;
			bBack.WidthRequest = 200;
			bFwd.WidthRequest = 200;
			bBack.Clicked += OnBackButtonClicked;
			bFwd.Clicked += OnFwdButtonClicked;
			LineChart.Chart.BeforeDraw += ChartBeforeDraw;
			LineChart.Chart.AfterDraw += ChartAfterDraw;
			LineChart.Chart.AutoRepaint = true;
			LineChart.WidthRequest = 400;
			LineChart.HeightRequest = 300;
			Content = new StackLayout
				Children =
						new StackLayout { Orientation=StackOrientation.Horizontal, Children = { bBack, bFwd } },
						LineChart
				VerticalOptions = LayoutOptions.CenterAndExpand,
				HorizontalOptions = LayoutOptions.CenterAndExpand,
			LineChart.Chart.Series.Add(new Line());
			double[] YValues = new double[] { 4000, 2500, 2200, 2000, 1800, 1700, 1500, 1300, 1100, 1000, 900, 850 };
			LineChart.Chart.Series[0].Add(YValues);
			(LineChart.Chart.Series[0] as Line).Marks.Visible = false;
			(LineChart.Chart.Series[0] as Line).LinePen.Width = 5;
			(LineChart.Chart.Series[0] as Line).Pointer.Visible = true;
			LineChart.Chart.Panel.Gradient.Visible = false;
			LineChart.Chart.Panel.Color = Color.White;
			LineChart.Chart.Walls.Left.Color = Color.White;
			LineChart.Chart.Walls.Bottom.Color = Color.White;
			LineChart.Chart.Walls.Back.Transparent = true;
			LineChart.Chart.Walls.Back.Pen.Color = Color.LightGray;
			LineChart.Chart.Legend.Visible = true;
			LineChart.Chart.Aspect.ColorPaletteIndex = 17;
			LineChart.Chart.Title.Text = "Pan to show the Nearest Point !";
			LineChart.Chart.Title.Alignment = TextAlignment.End;
			LineChart.Chart.Axes.Left.Increment = 500;
			LineChart.Chart.Axes.Left.AxisPen.Visible = false;
			LineChart.Chart.Axes.Bottom.AxisPen.Visible = false;
			LineChart.Chart.Panel.MarginBottom += 25;
			LineChart.Chart.Panel.MarginLeft -= 1;
			LineChart.Chart.Title.Font.Color = Color.Gray;
			LineChart.Chart.Walls.Left.Pen.Width = 1;
			LineChart.Chart.Walls.Bottom.Pen.Width = 2;
			LineChart.Chart.Walls.Left.Pen.Color = Color.LightGray;
			LineChart.Chart.Walls.Bottom.Pen.Color = Color.LightGray;
			LineChart.Chart.Aspect.View3D = false;
			Steema.TeeChart.Tools.NearestPoint NearestTool = new Steema.TeeChart.Tools.NearestPoint(LineChart.Chart);
			NearestTool.Series = LineChart.Chart.Series[0];
			NearestTool.Pen.Width = 3;
			NearestTool.Pen.Color = Color.Blue;
			NearestTool.Change += NearestTool_Change;
			LineChart.Chart.Panning.Allow = ScrollModes.None;
			if (Device.OS == TargetPlatform.Windows)
				LineChart.Chart.Touch.Style = TouchStyle.FullChart; //currently required for UWP. Will be replaced.
				LineChart.Chart.Title.Text = "";
				LineChart.Chart.Walls.Back.Gradient.Visible = false;
				LineChart.Chart.Walls.Back.Color = Color.White;
				LineChart.Chart.Panel.MarginBottom -= 25;
				LineChart.Chart.Axes.Left.MinimumOffset = 5;
				LineChart.Chart.Axes.Left.MaximumOffset = 4;
		private void NearestTool_Change(object sender, EventArgs e)
			LineChart.Chart.Title.Text = "Point Value : " + LineChart.Chart.Series[0].YValues[(sender as NearestPoint).Point].ToString();
		int currentIndex = -1;
		Steema.TeeChart.Drawing.ChartBrush pBrush;
		void OnFwdButtonClicked(object sender, EventArgs e)
			if (currentIndex < LineChart.Chart.Series[0].Count - 1)
				currentIndex++;
				pBrush = LineChart.Chart.Series[0].bBrush;
				pBrush.Transparency = 75;
				LineChart.Chart.Invalidate();
		void OnBackButtonClicked(object sender, EventArgs e)
			if (currentIndex > 0)
				currentIndex--;
		void ChartBeforeDraw(object sender, Steema.TeeChart.Drawing.Graphics3D g)
			//debug
			g.Font.Size = 8;
			g.TextOut(10, 10, "repaint count: " + bCounter++.ToString());
		int bCounter = 0;
		void ChartAfterDraw(object sender, Steema.TeeChart.Drawing.Graphics3D g)
			if (currentIndex != -1)
				double xCenter = LineChart.Chart.Series[0].CalcXPos(currentIndex);
				double yCenter = LineChart.Chart.Series[0].CalcYPos(currentIndex);
				g.Font.Size = g.Font.Size * 1.5;
				double offSet = 0;
				g.TextOut(xCenter - offSet, yCenter - (g.Font.Size * 4), " Value: " + LineChart.Chart.Series[0].YValues[currentIndex].ToString());
				Rectangle r = new Rectangle(xCenter - 25, yCenter - 25, 50, 50);
				g.Brush = pBrush;
				g.Pen.Width = 4;
				g.Ellipse(r);
Any suggestions on how to fix it?
18286055
Re: IOS bug for TeeChart. Xamarin.Forms
Post by 18286055 » Fri May 03, 2019 9:05 pm
The issue was "Steema.TeeChart.TChart.Init();" was not added to
[Register("AppDelegate")]
    public partial class AppDelegate : global::Xamarin.Forms.Platform.iOS.FormsApplicationDelegate
        // This method is invoked when the application has loaded and is ready to run. In this
        // method you should instantiate the window, load the UI into it and then make the window
        // visible.
        // You have 17 seconds to return from this method, or iOS will terminate your application.
        public override bool FinishedLaunching(UIApplication app, NSDictionary options)
            global::Xamarin.Forms.Forms.Init();
            LoadApplication(new App());
            return base.FinishedLaunching(app, options);
