TChart7 problem during installation... !?
ASI
Post by ASI » Mon Nov 22, 2004 9:23 am
Hi! I have also the problem during installation of TeeChart Pro 7.0 VCL/CLX under D8 .Net.
When I confirm 'Install TeeChart assemblies to . Net Global Assembly Cache?'
I receive below information:
'Error: Cannot find .Net GACUTIL.EXE tool in curent path'.
I found above file in two places:
C:\Program Files\Microsoft.NET\SDK\v1.1\Bin
C:\Program Files\ComponentOne Studio.NET\bin
Why it`s not working correctly?
I tested Your product with D6 without any problems.
Please, inform me what I shoud do...
BR
ASI
Post by Narcís » Mon Nov 22, 2004 10:48 am
HI ASI,
Please follow those steps to install TeeChart into Delphi 8:
- Install all the Delphi8 patches.
- Download the TeeChart Pro sources
- Run the installer of TeeChart pro v7 with sources
- Go to C:\Program Files\Steema Software\TeeChart Pro v7 Full Source Code
- Run the TeeRecompile tool
- Uncheck all the Delphi/bcb version, but not the Delphi 8, uncheck the recreate all XFM and "recompile Decision cube packages" options.
- Click begin (if you get an error about the GacUttil, skip it and close the TeeRecompile tool).
- It has created the following folder which contains the dlls. (C:\Program Files\Steema Software\TeeChart Pro v7 Full Source Code\Sources\Compiled\Delphi8)
- Then open Delphi8 and go to menu -> components -> install NET Components
- Go to NET VCL Components tab
- click Add buton and browse at C:\Program Files\Steema Software\TeeChart Pro v7 Full Source Code\Sources\Compiled\Delphi8\Assemblies
- and add the Steema.TeeChart.VCL.Design.dll
-This will add the TeeChart palette.
From now, please post your questions to the VCL forums.
