Access deny when try to view a chart
Amy
Post by Amy » Thu Nov 18, 2004 8:58 pm
All,
When I tried to view the chart on web, An error mesaage displays...
Access to the path "C:\Program Files\Steema Software\TeeChart for .NET v1\TeeChartForNET\_chart_temp\WebChart1172162005383096604262847.png" is denied.
I know it's a security issue. How do I fix it? However, when I tried to view the chart on the server (Local machine), there is no error.
Amy
Post by Narcís » Fri Nov 19, 2004 10:22 am
Hi Amy,
This may be due to the default security configuration of IIS6.0.
To remedy the problem, follow the instructions indicated in the error message for the file "C:\Program Files\Steema Software\TeeChart for .NET v1\TeeChartForNET\_chart_temp"
The _chart_temp is a folder created by TeeChart for .NET to temporaly save the images showed in the web page. You will have to grant permissions to store them.
Amy
Solved
Post by Amy » Fri Nov 19, 2004 2:21 pm
Thanks Narcis. The issue has been solved according to your idea.
Amy
