Legend with Continous = true and formatting of legind text
1) How do I get the legend to span the entire ChartRect.Height? as shown in the attached graphs, it only spans the top of the chart?
2) How do I format the legend text so that it becomes - for instance - 128,6 instead of 128,577 ??
- unknown.JPEG (180.93 KiB) Viewed 19431 times
- Site Admin
- Contact:
Re: Legend with Continous = true and formatting of legind text
Hi Friis,
1. What about something like this?
2. You can modify legend text format in the GetLegenText event, for example:
InitializeChart();
tChart1.Series.Add(new ColorGrid()).FillSampleValues();
tChart1.GetLegendRect += tChart1_GetLegendRect;
tChart1.Legend.Symbol.Continous = true;
tChart1.Legend.Font.Size = 14;
void tChart1_GetLegendRect(object sender, GetLegendRectEventArgs e)
Rectangle chartRect = this.tChart1.Chart.ChartRect;
e.Rectangle = new Rectangle(e.Rectangle.Left, chartRect.Top, e.Rectangle.Width, chartRect.Height);
void tChart1_GetLegendText(object sender, GetLegendTextEventArgs e)
double tmp = Convert.ToDouble(e.Text);
e.Text = tmp.ToString("0.000");
1) This does not solve the problem - try to test the code I have made below on your system - can you reproduce the problem?
2) Thank you - I will use this
Make3DGraph();
public void Make3DGraph()
try
this.tChart1.Series.Clear();
this.tChart1.Series.RemoveAllSeries();
this.tChart1.Dock = DockStyle.Fill;
this.tChart1.BackColor = Color.White;
this.tChart1.Walls.Back.Gradient.Visible = false;
this.tChart1.Walls.Back.Color = Color.White;
this.tChart1.Walls.Bottom.Gradient.Visible = false;
this.tChart1.Walls.Bottom.Color = Color.White;
this.tChart1.Panel.Gradient.Visible = false;
this.tChart1.Panel.Color = Color.White;
this.tChart1.Aspect.View3D = false;
this.tChart1.Panel.Bevel.Outer = Steema.TeeChart.Drawing.BevelStyles.None;
this.tChart1.Axes.Left.Automatic = true;
this.tChart1.Axes.Bottom.Automatic = true;
this.tChart1.Axes.Left.Title.Caption = "";
this.tChart1.Axes.Bottom.Title.Caption = "";
this.tChart1.Header.Text = "";
this.tChart1.Header.Font.Size = 14;
this.tChart1.Legend.VertSpacing = 0;
this.tChart1.Legend.Symbol.Width = 100;
this.tChart1.Legend.Transparent = false;
this.tChart1.Legend.Symbol.DefaultPen = false;
this.tChart1.Legend.Symbol.Continous = true;
this.tChart1.Legend.Symbol.Pen.Color = Color.White;
this.tChart1.Legend.Symbol.Pen.Width = 1;
this.tChart1.Legend.DividingLines.Visible = false;
this.tChart1.Legend.Symbol.Width = 50;
this.tChart1.Legend.Symbol.Squared = true;
this.tChart1.Legend.Visible = true;
this.tChart1.Legend.Shadow.Visible = true;
this.tChart1.Legend.Font.Size = 14;
this.tChart1.Axes.Left.Title.Text = "Power / MW";
this.tChart1.Axes.Left.Title.Font.Size = 14;
this.tChart1.Axes.Bottom.Title.Text = "Q / MJ/s";
this.tChart1.Axes.Bottom.Title.Font.Size = 14;
Steema.TeeChart.Styles.ColorGrid ColorGridSeries1 = new Steema.TeeChart.Styles.ColorGrid(tChart1.Chart);
this.tChart1.Series.Add(ColorGridSeries1);
ColorGridSeries1.Pen.Visible = false;
ColorGridSeries1.Title = "surface1";
ColorGridSeries1.UseColorRange = false;
ColorGridSeries1.UsePalette = true;
ColorGridSeries1.IrregularGrid = true;
ColorGridSeries1.CenteredPoints = true;
for (double x = 0; x < 10; x += 0.1) // = 10 rows
for (double z = 0; z < 10; z += 0.1) // = 10 columns
ColorGridSeries1.Add(x, x*z, z);
Color[] ColorPalette = new Color[100];
double[] ColorSteps;
ColorPalette = SetColorPalette(1, out ColorSteps);
for (int i = 0; i < ColorPalette.Length; i++)
ColorGridSeries1.AddPalette(ColorSteps[i], ColorPalette[i]);
catch (Exception ex)
MessageBox.Show(ex.Message);
private Color[] SetColorPalette(byte Index, out double[] ColorSteps)
double max;
double min;
ColorSteps = new double[100];
ColorSteps[0] = 0;
ColorPalette[0] = Color.White;
for (int i = 1; i < 100; i++)
ColorPalette[i] = CoolColorCode(i);
for (int i = 1; i < ColorPalette.Length; i++)
ColorSteps[i] = i;
return ColorPalette;
private void tChart1_GetLegendRect(object sender, Steema.TeeChart.GetLegendRectEventArgs e)
private Color CoolColorCode(double ColorValue)
ColorValue = 100 - ColorValue;
if (ColorValue < 0)
ColorValue = 0;
else if (ColorValue > 100)
ColorValue = 100;
if (ColorValue < 25)
return Color.FromArgb(255, Convert.ToInt16(ColorValue / 25 * 255), 0);
else if (ColorValue < 50)
return Color.FromArgb(Convert.ToInt16(255 - ((ColorValue - 25) / 25 * 255)), 255, 0);
else if (ColorValue < 75)
return Color.FromArgb(0, 255, Convert.ToInt16((ColorValue - 50) / 25 * 255));
return Color.FromArgb(0, Convert.ToInt16(255 - Math.Round((ColorValue - 75) / 25 * 255)), 255);
1) Perhaps I'm not explaining the problem well enough. The blue squared symbol with a value of 15.175 in the attached image "unknown.jpeg" - I would like to have that moved down to the very bottom and the red squared symbol with a value of 128.577 to stay at the top. In that way do make the legend values show a larger range of values and colors
- Site Admin
- Contact:
Hi Friis,
1. This highly depends on the chart size. Another variable you can throw into the mix is Legend.VertSpacing:
You can make those values relative to the chart height.
this.tChart1.Legend.VertSpacing = 10;
Hi Narcis,
OK, vertspacing makes it look a little better...
But, for instance, in the attached image "unknown.jpeg" there are 10 symbols ranging from 0 to 128.577 - isn't it possible to increase this number to a larger number so that you accomplish a smoother gradient and larger gradient?
for instance, in the attached image "untitled.jpg" the legend is very smooth and there are an "unlimited" amounts of symbols ??
- untitled.jpg (21.86 KiB) Viewed 19365 times
- Site Admin
- Contact:
Hi Friis,
You'd better use LegendPalette tool for that. You'll find an example at "All Features\Welcome !\Tools\Legend Palette" in the features demo available at TeeChart's program group. This applied to your example:
InitializeChart();
//this.tChart1.Axes.Left.Title.Font.Size = 14;
//this.tChart1.Axes.Bottom.Title.Font.Size = 14;
ColorGridSeries1.Add(x, x * z, z);
legendPalette1 = new LegendPalette(tChart1.Chart);
legendPalette1.Series = ColorGridSeries1;
tChart1.GetAxesChartRect += tChart1_GetAxesChartRect;
tChart1.Panel.MarginUnits = PanelMarginUnits.Pixels;
tChart1.Panel.MarginRight = legendPalette1.Width + 10;
private Steema.TeeChart.Tools.LegendPalette legendPalette1;
void tChart1_GetAxesChartRect(object sender, GetAxesChartRectEventArgs e)
legendPalette1.PositionUnits = PositionUnits.Pixels;
legendPalette1.Top = e.AxesChartRect.Top;
legendPalette1.Left = e.AxesChartRect.Right + 5;
legendPalette1.Height = e.AxesChartRect.Height;
ColorSteps[0] = 0;
ColorSteps[i] = i;
if (ColorValue < 0)
ColorValue = 0;
ColorValue = 100;
That looks MUCH better - Thank you
However, if I set the
this looks strange - the font at the legend palette looks bold ??
legendPalette1.Transparent = false;
- StrangeLookingLegendPalette.png (7.68 KiB) Viewed 19348 times
- LegendPaletteOK but not transparent.png (8.08 KiB) Viewed 19357 times
- Site Admin
- Contact:
Hi Friis,
This looks like a bug to me. I have added it (ID971) to the bug list to be fixed for future releases.
Hi Again,
How do I add a title to the legendPalette?
The following code does not work?
and
just adds a title to the chart itself ?
legendPalette1.title.text = "sasasf";
legendPalette1.chart.header.text = "dsf";
- Guru
Yes; in the meantime, a simple workaround is this:Narcís wrote:This looks like a bug to me. I have added it (ID971) to the bug list to be fixed for future releases.
Steema.TeeChart.Tools.LegendPalette legendPalette1 = new LegendPalette(tChart1.Chart);
legendPalette1.Series = tChart1[0];
legendPalette1.Axes.Chart.Graphics3D.TextRenderingHint = System.Drawing.Text.TextRenderingHint.SystemDefault;
legendPalette1.Transparent = true;
- Guru
Try:Friis wrote:just adds a title to the chart itself ?
legendPalette1.Axes.Chart.Header.Visible = true;
legendPalette1.Axes.Chart.Header.Text = "asasas";
Just implemented both of the solutions you have presented here - it works fantastic both of them - thank you
