How to fit all the lines into a chart
I have a fixed tool window as a client and on which a teechart is docked. Now I try to place some lines whose lengths are not know and upon doing it the part of the line is beyond the size of teechart.
How can I fit all the lines into a teechart? In future, the fixed tool window may be re-sizable.
- Guru
Re: How to fit all the lines into a chart
Raavi,
Would you be so kind as to create a Short, Self Contained, Correct (Compilable), Example with which I can see your issue here?Raavi wrote:I have a fixed tool window as a client and on which a teechart is docked. Now I try to place some lines whose lengths are not know and upon doing it the part of the line is beyond the size of teechart.
Sorry. I have to pick up the right words or an example to demonstrate.
But, I got 'false' for 'Chart.Zoom.Zoomed'. which tells me that not all Chart point fit into Chart.
On clicking Test button one may notice the part of the rectangle goes out of the chart.
I rather like to implement to fit all the lines in the chart. Some sort of autozoom.
- TestingTeeChartScaling.zip
- (44.55 KiB) Downloaded 917 times
- Guru
If I change the code to:Raavi wrote:On clicking Test button one may notice the part of the rectangle goes out of the chart.
private void AddSeriesToChart()
m_Sum = 10.0;
1) What should I have to do thereby, 'm_Chart.Zoom.Zoomed' returns 'true'
2) If I set m_Sum += 10.0; then part of the lines go out of the Chart. This should not happen rather it should 'zoom out' to fit all lines in a given Chart size and the same for m_Sum -= 10 and in this case it should 'zoom in'.
* My problem is I cannot change the Chart size so I have to play with Zoom in and Zoom out by keeping Aspect ratio fixed either horizontally or vertically.
- Guru
I see. Maybe the problem is that the internal Series statistics aren't being updated as you set the ValueList.Value array directly. You could try:Raavi wrote:1) What should I have to do thereby, 'm_Chart.Zoom.Zoomed' returns 'true'
m_Line.XValues.Count = 6;
m_Line.XValues.Value = m_RectangleX;
m_Line.XValues.Modified = true;
m_Line.YValues.Count = 6;
m_Line.YValues.Value = m_RectangleY;
m_Line.YValues.Modified = true;
I think, I can demonstrate what I mean about the lines not fitting into the chart with the attached solution.
* I cannot change the size of the Chart.
* I do not know what the dimensions for the line are.
In that case, however the line is defined it should fit into Chart.
- (45.92 KiB) Downloaded 930 times
- Guru
Try:Raavi wrote:I think, I can demonstrate what I mean about the lines not fitting into the chart with the attached solution.
m_Chart.Axes.Bottom.Automatic = true;
m_Chart.Axes.Bottom.MinimumOffset = 10;
m_Chart.Axes.Bottom.MaximumOffset = 10;
//m_Chart.Axes.Bottom.Visible = false;
m_Chart.Axes.Bottom.Ticks.Length = 0;
m_Chart.Axes.Bottom.Labels.Visible = false;
m_Chart.Axes.Bottom.AxisPen.Visible = false;
m_Chart.Axes.Left.Automatic = true;
m_Chart.Axes.Left.MinimumOffset = 10;
m_Chart.Axes.Left.MaximumOffset = 10;
//m_Chart.Axes.Left.Visible = false;
m_Chart.Axes.Left.Ticks.Length = 0;
m_Chart.Axes.Left.Labels.Visible = false;
m_Chart.Axes.Left.AxisPen.Visible = false;
I beg your pardon, I do not see any change with the suggestion.
- Guru
Yes, I'm sorry, those changes seem to be irrelevant. The relevant change is commenting out this line:Raavi wrote:I beg your pardon, I do not see any change with the suggestion.
//m_Chart.BeforeDrawSeries += (sender, d) => m_Chart.Chart.Axes.Bottom.AdjustMaxMin();
Works but it breaks on re-sizing the window.
Nice video demonstration. Thanks.
Though it is not a strict criterion but things may change in the future. Like, fixed size Chart to re-sizable.
- Guru
I'm sorry, I thought that when you said "I cannot change the size of the Chart." you meant that the size of the Chart couldn't be changed.Raavi wrote:Works but it breaks on re-sizing the window.
So the size of the Chart *can* be changed, but only when the client resizes, is that correct?
- Guru
If I comment out the line:Raavi wrote:Though it is not a strict criterion but things may change in the future. Like, fixed size Chart to re-sizable.
//m_Line.IsoHorizAxes = true;
I am a little confused as to exactly what your requirements are, I'm sorry.
