ScrollPager doesn't respect the margin of customaxis
acastro
Post by acastro » Wed Mar 05, 2014 11:09 am
If I have a custom axis with a manually set margin and I add a page scroller it doesn respect the margin.
Please find the example, press button2, and the button1
http://193.145.251.126/pnp/files/rjiKjX ... croll2.zip
Re: ScrollPager doesn't respect the margin of customaxis
Post by Christopher » Thu Mar 06, 2014 10:30 am
wakeup wrote:If I have a custom axis with a manually set margin and I add a page scroller it doesn respect the margin.
As we've discussed before, I believe, the ScrollPagerTool uses sets TChart.Chart.CustomChartRect to TRUE every time it is painted, so making these margins non-functional. One workaround would be:
          AddCustomAxis();
          tChart1.BeforeDraw += tChart1_BeforeDraw;
          tChart1.Invalidate();
        private void AddCustomAxis()
          Steema.TeeChart.Axis customAxis = new Steema.TeeChart.Axis(tChart1.Chart);
          customAxis.Title.Visible = false;
          customAxis.Visible = false;
          customAxis.Horizontal = false;
          customAxis.Automatic = true;
          customAxis.Ticks.Color = tChart1.Series[0].Color;
          customAxis.AxisPen.Color = tChart1.Series[0].Color;
          customAxis.Labels.Font.Color = tChart1.Series[0].Color;
          tChart1.Axes.Custom.Add(customAxis);
          tChart1.Series[0].CustomVertAxis = customAxis;
          tChart1.Series[0].CustomVertAxis.Visible = true;
        void tChart1_BeforeDraw(object sender, Steema.TeeChart.Drawing.Graphics3D g)
          double maxVal = tChart1.Series[0].YValues.Maximum;
          float width = tChart1.Graphics3D.TextWidth(maxVal.ToString(tChart1.Series[0].CustomVertAxis.Labels.ValueFormat));
          Rectangle rect = tChart1.Chart.ChartRect;
          rect.X = Steema.TeeChart.Utils.Round((width * 1) + 30);
          rect.Width = tChart1.Width - 80;
          tChart1.Chart.ChartRect = rect;
acastro
Post by acastro » Thu Mar 06, 2014 10:40 am
Ok thanks, but with that code the scrollpager axis doesn't have any values...
Post by Christopher » Thu Mar 06, 2014 10:48 am
wakeup wrote:Ok thanks, but with that code the scrollpager axis doesn't have any values...
It does have values here.
This is the code for the entire form, which I'm using with TeeChart.dll version 4.1.2014.2062 (net40):
using System;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Windows.Forms;
namespace TestPageScroll2
            Steema.TeeChart.Styles.Line line = new Steema.TeeChart.Styles.Line();
            tChart1.Series.Add(line);
            tChart1.Series[0].FillSampleValues();
            Steema.TeeChart.Tools.ScrollPager mt = new Steema.TeeChart.Tools.ScrollPager(tChart1.Chart);
            for (int i = 0; i < tChart1.Series.Count; i++)
                if (tChart1.Series[i].Count > 0)
                    mt.Series = tChart1.Series[i];
          AddCustomAxis();
acastro
Post by acastro » Thu Mar 06, 2014 10:55 am
Please press first the button2 to add the custom axis, and then button1 to add the scrollpager
Post by Christopher » Thu Mar 06, 2014 11:11 am
wakeup wrote:Please press first the button2 to add the custom axis, and then button1 to add the scrollpager
Yes, that's because when the ScrollPagerTool clones the Series internally, it clones a series with a custom axes specified onto a chart that does not have one.
That is to say, if you wish to use a Custom Axis in a Chart with an associated ScrollPagerTool, please make sure you set the ScrollPagerTool.Series property before you do so, as one does by pressing button1 and then button2.
acastro
Post by acastro » Thu Mar 06, 2014 11:30 am
I don't understand you, the chart have the custom axis... what doesn't have the chart?
Christopher wrote: That is to say, if you wish to use a Custom Axis in a Chart with an associated ScrollPagerTool, please make sure you set the ScrollPagerTool.Series property before you do so, as one does by pressing button1 and then button2.
Set the scrollPagerTool.series, before I do what? I cannot set the scrollpagertool.series before add the scrollepagertool. And I don't know when the user is going to be interested in add a scrollerpager or not...
Post by Christopher » Thu Mar 06, 2014 11:40 am
wakeup wrote: I don't understand you, the chart have the custom axis... what doesn't have the chart?
No, I'm not surprised you don't understand me, as you don't have access to the TeeChart source code and I do. If you had access to it, you would understand me much easier, I think :D
The ScrollPagerTool is a very complex tool and uses several other TeeChart tools internally. One of these tools is the SubChartTool, and it is this tool that presents a *secondary* chart underneath the *primary* chart when you add in a ScrollPagerTool, and this *secondary* chart has a clone of the Series in the *primary* chart. If the series in the primary chart is cloned when it has a custom axis associated to it, when it is rendered in the secondary chart it does not appear, as the secondary chart does not actually contain a custom axes.
wakeup wrote: Set the scrollPagerTool.series, before I do what? I cannot set the scrollpagertool.series before add the scrollepagertool. And I don't know when the user is going to be interested in add a scrollerpager or not...
No, that's not what I'm saying. The order is:
1) Add a Chart to a Windows Form
2) Add a series to the chart
3) Add a SubChartTool to the chart
4) Set the SubChartTool.Series property to the series in the chart
5) Add the custom axis to the series ("primary") of the chart
acastro
Post by acastro » Thu Mar 06, 2014 11:47 am
So, do you mean Scrollpagertool doesn't support custom axis?
Yes in that order it runs, but I'm saying it doesn't run in this order:
3) Add the custom axis to the series ("primary") of the chart[/quote]
4) Add a SubChartTool to the chart
5) Set the SubChartTool.Series property to the series in the chart
Post by Christopher » Thu Mar 06, 2014 11:51 am
wakeup wrote: So, do you mean Scrollpagertool doesn't support custom axis?
No, I'm not saying that. What I'm saying is that if you want to use Chart with a ScrollPagerTool and have the Series in the primary (top) Chart associated to a custom axis, then you will have to associate the custom axis to the Series before associating the Series to the ScrollPagerTool.Series property.
wakeup wrote: Yes in that order it runs, but I'm saying it doesn't run in this order:
Yes, I know it doesn't run in that order, I have given you an explanation for why it doesn't run, I have just given you my best suggestion (above) for how to work in the case of having a Series associated with a custom axis in the primary (top) chart.
acastro
Post by acastro » Thu Mar 06, 2014 12:25 pm
I think I do that. I associate the custom axis to the serie in button2, and then in Button1 I set the ScrollPagerTool.Series property...
Christopher wrote: Yes, I know it doesn't run in that order
So, is it not a bug? I need to do it in that order, because the normal behabiour of a user is to do it in that order...
Post by Christopher » Thu Mar 06, 2014 1:52 pm
wakeup wrote:I think I do that. I associate the custom axis to the serie in button2, and then in Button1 I set the ScrollPagerTool.Series property...
Yes, you do, my mistake. I shall restate my position:
What I'm saying is that if you want to use Chart with a ScrollPagerTool and have the Series in the primary (top) Chart associated to a custom axis, then you will have to associate the custom axis to the Series *AFTER* associating the Series to the ScrollPagerTool.Series property.
Christopher wrote:So, is it not a bug? I need to do it in that order, because the normal behabiour of a user is to do it in that order...
I don't see neither associating the custom axis to the Series *AFTER* associating the Series to the ScrollPagerTool.Series property nor associating the custom axis to the Series *BEFORE* associating the Series to the ScrollPagerTool.Series property as "normal" user behaviour.
AFAIC, it's a bit like saying that this code:
      tChart1[0].FillSampleValues();
      tChart1.Series.Add(typeof(Line));
Is a bug as the code will only work if the two lines are in reverse order.
acastro
Post by acastro » Thu Mar 06, 2014 3:16 pm
Ok, then I have another related question. Please try this example:
http://193.145.251.126/pnp/files/PVSpTe ... croll2.zip
Press button1, then button2. And finally what is missing in button4 in order to run sucessfully updating the data and having the axis in the scrollpager right?
Post by Christopher » Fri Mar 07, 2014 11:37 am
wakeup wrote:Press button1, then button2. And finally what is missing in button4 in order to run sucessfully updating the data and having the axis in the scrollpager right?
I'm not sure exactly what you're looking for here, but you can line up the primary and secondary charts with code such as:
      width *= 1.3f;
      mt.SubChartTChart.Chart.CustomChartRect = true;
      rect.X -= Steema.TeeChart.Utils.Round(width);
      rect.Width += Steema.TeeChart.Utils.Round(width);
      mt.SubChartTChart.Chart.ChartRect = rect;
acastro
Post by acastro » Fri Mar 07, 2014 12:16 pm
What I'm asking is how is the right way to update the data of a serie in that case. Itried with the code in the button4 but it creates a lot of new series in the subchart.
