Need help accessing properties.
brotsten
Post by brotsten » Fri Jan 18, 2013 8:36 pm
I'm new to C# and I'm having a problem accessing some series properties.
This works fine where I already have a statically defined series:
private void PointsCheckBox_CheckedChanged(object sender, EventArgs e)
this.line1.Pointer.Visible = this.PointsCheckBox.Checked;
Later during execution, I add some more series to the chart. I would like to set the property as above, Pointer.Visible, but it's not available:
foreach (int i in this.theLargeChart.Series)
this.theLargeChart.Series.
} ................................^^^^^^^This property is not visible here.
Could someone show me how I can access that property?
Brian
Re: Need help accessing properties.
Post by Sandra » Mon Jan 21, 2013 10:36 am
Hello Brian,
Your problem is produced because, not all series have the pointer property. For this reason to access pointer property, you must define the type of series as you are using as do in next line of code:
(Chart1.Series[i] as Steema.TeeChart.Styles.Line).Pointer.Visible= true;
Could you tell us if previous code works in your end?
brotsten
Post by brotsten » Mon Jan 21, 2013 4:09 pm
Thank you Sandra, that was exactly what I needed.
Brian
Post by Sandra » Tue Jan 22, 2013 9:29 am
Hello Brian,
I am glad that suggestion helps you :).
