Point control selection problem
vivek
Post by vivek » Tue Nov 10, 2009 6:36 am
I have developed point selection in TChart V3(Dll version is 3.5.3425.20244), it was working fine.
Now i have installed TeeChartNET2009VSNET2005 . Dll version is 4.0.2009.28593
I am facing selection problem with Point series.
I have added Point series and MarksTip tool in TChart control.
Then have added 3 or 4 same data inputs in the point series. If i move mouse on top of those points, it is showing above/top lable. But if i try to get the lable/valueIndex of selected points after clicking on series, its giving the below/bottom point's lable instead of above/top point's lable.
example,
points1.Add(5, 10, "A");
points1.Add(5, 10, "B");
points1.Add(5, 10, "C");
private void tChart1_ClickSeries(object sender, Steema.TeeChart.Styles.Series s, int valueIndex, MouseEventArgs e)
//tChart1.Header.Text = points1[valueIndex].Label;
if (points1[valueIndex].Color == selectedCellColor)
points1[valueIndex].Color = Color.Black;
points1[valueIndex].Color = selectedCellColor;
The above code working fine in TChart dll 3.5.3425.20244. But it is not working in TChart dll 4.0.2009.28593.
How to solve this problem?
With Regards,
Vivek
Re: Point control selection problem
Post by Sandra » Thu Nov 12, 2009 10:08 am
Hello vivek,
Thanks for your information, I could reproduce your problem here. I have added it in bug report list with number [TF02014559] and we will try to fix for next versions of TeeChart .Net
vivek
Post by vivek » Thu Nov 12, 2009 10:19 am
Hello sandra,
Do you have any temporary solution to solve this problem?
With regards,
Vivek.J
Post by Yeray » Thu Nov 12, 2009 11:10 am
Hi Vivek,
I'm afraid that the only thing I can think right now would be looping into your series searching for all the points in the same position. Something like following:
        private Steema.TeeChart.Styles.Points points1;
        private Steema.TeeChart.Tools.MarksTip marktip;
            points1 = new Steema.TeeChart.Styles.Points(tChart1.Chart);
            marktip = new Steema.TeeChart.Tools.MarksTip(tChart1.Chart);
            marktip.Series = points1;
            tChart1.ClickSeries += new Steema.TeeChart.TChart.SeriesEventHandler(tChart1_ClickSeries);
            int first, last;
            first = last = -1;
            for (int i = 0; i < tChart1[0].Count; i++)
                if ((tChart1[0].XValues[i] == tChart1[0].XValues[valueIndex]) && (tChart1[0].YValues[i] == tChart1[0].YValues[valueIndex]))
                    if (first == -1) first = i;
                    last = i;
            if ((first != -1) && (last != -1))
                tChart1.Header.Text = "first: " + tChart1[0].Labels[first] + "  last: " + tChart1[0].Labels[last];
