Silverlight : Rectangle / Annotation tool edit
Priya Hatipkar
Post by Priya Hatipkar » Fri Jul 24, 2009 10:00 am
hi
I am trying to make a simple feature where a user can add a rectangle tool to the chart , edit the text , later delete the annotation/rectangle tool
so i will have methods like addAnnotation , removAannotation and am planning to add editing using the AllowEdit = true and using Keydown event as follows
(below "annotation" can be rectangletool or annotation)
void annotation_KeyDown(object sender, KeyEventArgs e)
if (e.Key == Key.Enter)
currentAnnotationTool.EndEdit();
if(e.Key == Key.F2)
currentAnnotationTool.StartEdit();
is the below logic correct?
Have a flag to set which tool is selected - defalt = false
Add a annotation and set the flag to false
On click of the annotation , set the flag to true and set the currentannotation = selectedannotation
on keydown startedit on enter and endedit on F2(key can be any key)
in deleteAnnotation , remove the annotation from the chart tool collection
I am not able to hit the keydown event , I am able to hit the click event . do we have a sample to show how to use rectangletool for editing .
Also I saw that the rectangle shape "roundrectangle" is available , but the Shape property for rectangletool is readonly , so how can i have a round rectangle on my chart .
What is the use of EditorKey() eventhandler .
thanks,
Aniket
Re: Silverlight : Rectangle / Annotation tool edit
Post by Narcís » Fri Jul 24, 2009 1:33 pm
Hi Aniket,
Yes, it seems fine to me.
I've checked that KeyDown event and RectangleTool editing doesn't work in TeeChart.Silverligh.dll. I've added these to the wish-list to be enchanced for future releases. In such circumstances, the only solution I can think of for editing a RectangleTool is using a textbox and assigning the text to the tool.
Code below works fine for me here.
			rectangle1.Shape.ShapeStyle = Steema.TeeChart.Silverlight.Drawing.TextShapeStyle.RoundRectangle;
What is the use of EditorKey() eventhandler.
It's is for checking which key has been pressed in an editor.
Priya Hatipkar
Post by Priya Hatipkar » Mon Jul 27, 2009 6:38 am
Hi Narcis,
Thanks for the roundrect comment , it does work , I must have set someting else :).
On the annotation/rect editing .....
" I've checked that KeyDown event and RectangleTool editing doesn't work in TeeChart.Silverligh.dll. I've added these to the wish-list to be enchanced for future releases. In such circumstances, the only solution I can think of for editing a RectangleTool is using a textbox and assigning the text to the tool "
I checked in windows samples for the annotation/rect editing it works (canedit), shouldnt it be a bug for silverlight implementation ? I mean the logic i am trying to implement is because "CanEdit" is not working , even the Keydown event works in windows samples , so request teechart to take it as a bug . Am sure people will want to add and edit annotations/text set for thier charts , specially financial charts , in place editing should work the same way as in wondows samples .
which release will this fix/feature be a part of ? this is part of my (must have)requirements so need it quickly mate .
Thanks for the textbox suggestion , I did try the same , it works but , it doesnt provide the same utility/effect as the "in place" editing of recttool/annotation , which we have in windows .
thanks,
Aniket
Post by Narcís » Mon Jul 27, 2009 8:49 am
Hi Aniket,
Yes, we know that works with Windows Forms applications. However Silverlight is almost and independent framework so, even though TeeChart.Silverlight.dll reuses TeeChart.dll code, I'm not sure if this should be considered a bug or just needs to be reworked to be supported in TeeChart.Silverlight.dll.
I understand your position but I'm not able to provide an estimate date for now. I recommend you to be aware at this forum or subscribe to our RSS news feed for new release announcements and what's fixed and included on them.
