TeeChart for .NET version 2 Released
Steema is pleased to announce the availability of TeeChart for .NET version 2.
TeeChart for .NET v2 is packed with many new features including:
TeeChart Themes for template and colour palette management
New Axis features include alternate labelling, Top DepthAxis, Isometric Axes
New in Legend includes Scrollbar and Image symbolling
New in Series include BarSeries Depth control, symbols on marks, Pie Shadow and Slice-heights, Surface smoothing and LineSeries Interpolation
New Tools include a SurfaceSeries Nearest Point locator, Axis drag scrolling
New in Export includes EPS format
New functions include ADX, Bollinger, Correlation, Exponential Trend, MACD, Median, Mode, Perimiter, Reducing number of Points, RSI and Variance
New Series include Horizontal Histogram, Map GIS, Image Bar
New Text and XML Data Source Components
OpenGL Chart rendering
Extensive enhancements to Web functionality including Hotspot and Zoom Tools, and Mapping support
TeeChart for .NET is a 100% C#, Managed Component Suite. The TeeChart.Net Charting Control may be used on the desktop as well as in server-based and ASP.NET applications.The Standard functionality specification includes:
47 Chart styles (in 2D and 3D plus multiple combinations)
39 Functions (Standard, Financial, Statistical)
23 User Tools
Run-time Editor, Print-Preview, Gallery and Navigator bar
ASP.NET support with WebForm Chart
OpenGL Component
Data aware. Supports SQLDataAdapter, Dataviews and tables and imports Text and XML data
Exports to most standard image formats and several data formats including Excel and XML
Includes Multiple Axis support
Zoom and Scroll
Compact Framework PocketPC Charts
Please follow the link below to our new ASP.NET Demo:
http://www.steema.net/TeeChartForNET/index.aspx
You can order your upgrade from:
http://www.steema.com/ordering/order_tchnet_u.shtml
23 User Tools
OpenGL Component
Zoom and Scroll
Thank you!
http://groups.google.com
http://codenewsfast.com/
Hi Mike,
Yes, that demo is only a subset, gauge and radar series are included. If you download the trial version an run features demo you'll find all those series.I looked at the sample of v2. Is this a only a subset of the styles as I noticed that gauge and radar are not shown?
TeeCommander is not available in ASP.NET, however users can modify chart attributes as shown in the v2 WebForms demo where users can change values using listboxes, checkboxes, textboxes, etc. for each property you want users to be able to change.In version 1, the TeeCommander was not available in the ASP .NET charting environment. Is it or some means for the user to modify chart attributes available in v2?
Hi Matt,
Yes, I think you'll have to upgrade your current license. For more information please contact our sales department at sales@steema.com.
Upgrade
Thanks I appeciate the answer.
I don't want to install a trial version on my development system, I'm sure it will cause problems with the licenced version.
Yes, we have always been able to use dropdowns, but one for colour, one for style one for etc starts to get cumbersome.
Oh well, life is like that
Cheers
Mike McCann
Cheers
Mike McCann
Hi Mike,
You shouldn't have any problems as settings are absolutelly separated from other versions.I don't want to install a trial version on my development system, I'm sure it will cause problems with the licenced version.
Yes, but as chart editor uses WinForms it can't be used in a client browser.Yes, we have always been able to use dropdowns, but one for colour, one for style one for etc starts to get cumbersome.
TCommander
Yes, I knew that when I purcahsed v1. I would have liked it to be applied to webchart as well as TChart. No need to reply to this.
As it is I see no value in upgrading to v2.
Mike McCann
Mike McCann
Hi Mike,
For this you could use TeeChart Pro ActiveX free license included with TeeChart for .NET. ActiveX version will allow you using TeeChart and TeeCommander as a "live" object in a WebForm.Yes, I knew that when I purcahsed v1. I would have liked it to be applied to webchart as well as TChart. No need to reply to this.
Well, it will depend on your needs but, for example, if you browsed the web demo you must have appreciated several new features regarding webchart user interaction.As it is I see no value in upgrading to v2.
Narcís wrote:
Holger Persch
I just want to mention that I experienced that the assembly reference of an existing project using TeeChart .NET V1 was automatically changed to TeeChart .NET V2 after installing the trial version.You shouldn't have any problems as settings are absolutelly separated from other versions.
Holger Persch
Active X for .NET
The Active X sounds like it will solve what I want to do, which is let the end user interact and change series colours, transparency etc. . What is the upgrade / cross grade price from v.1 .NET to obtain .NET Active X
Mike McCann
And another question - is the Active X deployed on the server, and is there an lc.exe run required?
Mike McCann
Hi Mike,
A TeeChart Pro ActiveX license is freely given with any purchased TeeChart for .NET license. If you can't find yours keys please contact our sales department at sales@steema.com with your customer details.The Active X sounds like it will solve what I want to do, which is let the end user interact and change series colours, transparency etc. . What is the upgrade / cross grade price from v.1 .NET to obtain .NET Active X
ActiveX version can be used in a server and doesn't neet license files. For using ActiveX version in a web server you may require a Web Server Run-time license. For more information please have a look hereAnd another question - is the Active X deployed on the server, and is there an lc.exe run required?
