I am having a small issue plotting a simple bar chart.
The problem I'm having is that the first data point plotting a bar chart appears as a single line rather than a bar. Here is a link to a small video demonstrating the problem
ftp://innervations.dyndns-server.com/DO ... roblem.MP4
Here is a snippet of the source code that actually updates the TeeChart:
If Val(LabelCount.Text) > bars Then 'to stop add the same bar twice
If targetmet Then
If CheckBoxAudioFeedback.Checked Then My.Computer.Audio.Play(oversoundfile, AudioPlayMode.Background)
Bar1.Add(Val(LabelCount.Text), Val(LabelValue.Text), Color.Green)
bars = bars + 1
Else
If CheckBoxAudioFeedback.Checked Then My.Computer.Audio.Play(undersoundfile, AudioPlayMode.Background)
Bar1.Add(Val(LabelCount.Text), Val(LabelValue.Text), Color.Red)
bars = bars + 1
End If
End If
Any assistance to resolve this issue would be greatly appreciated.
Sincerely,
Rob
Problem with plotting bar graph
- Guru
Re: Problem with plotting bar graph
Hello Rob,
Yes, this issue was resolved in issue number 1794:
http://bugs.teechart.net/show_bug.cgi?id=1794
the resolution is present in build 4.1.2017.02140 released on 14th March 2017.
Brilliant. Thanks Christopher. I will download and install latest TeeChart now.
Cheers
Rob
Cheers
Rob
Have downloaded and installed TeeChart .NET Version 4.1.2017.2142. Install ran fine - no problem. I removed the reference to the older version and added the latest TeeChart.dll to the .NET references for my application (screen shot attached).
When I build and run my application I get the error that code generation could not load the old TeeChart.dll or one of its dependencies (screen shot attached).
Is there something else I have to change to update Visual Studio 2015 and my application to use the Version 4.1.2017.2142?
Rob
Rob
- Error on running app
- runtime error.jpg (42.13 KiB) Viewed 10804 times
- Screen shot of application references
- application references.jpg (249.02 KiB) Viewed 10804 times
Success!
I uninstalled and reinstalled the latest .NET version of TeeChart and all is working fine now.
Best Regards
Rob
Best Regards
Rob
