WPFDemo not working correctly when set to x64
tt54321
Post by tt54321 » Thu Oct 20, 2016 12:33 pm
The example DemoProjectWPF gives a 'Object reference not set to an instance of an object' when compiled using x64 - (configuration changed to x64 and reference changed to the x64 dll). I'm using Visual Studio 2013 version 12.0 and target framework .NET version 4.5.1.
I have a similar issue when I run my program which needs to be 64 bit. Is this an issue with TeeChart or has it not installed correctly on my machine?
Re: WPFDemo not working correctly when set to x64
Post by Christopher » Fri Oct 21, 2016 2:02 pm
tt54321 wrote:I have a similar issue when I run my program which needs to be 64 bit. Is this an issue with TeeChart or has it not installed correctly on my machine?
Are you referencing the x64 builds of TeeChart.WPF.dll? E.g.
