Bottom and Custom Vertical Axis Label Start Position
Priyanka
Re: Bottom and Custom Vertical Axis Label Start Position
Post by Priyanka » Mon May 30, 2016 7:07 am
Hi Christopher,
I have requirement to disable anti aliasing. I have tried below code.
WebChart1.Chart.Aspect.SmoothingMode = System.Drawing.Drawing2D.SmoothingMode.None;
However, it is not working in my case. Please assist.
Post by Christopher » Mon May 30, 2016 9:20 am
Priyanka wrote: I tried it but no luck.
Here is the code I am using with the latest version of TeeChart.dll:
and this is the result:
Priyanka
Post by Priyanka » Tue May 31, 2016 6:29 am
Thanks Christopher.
It removed extra borders. However, I need top and right border to only chart area as attached.
Post by Christopher » Wed Jun 01, 2016 8:31 am
Priyanka wrote:However, I need top and right border to only chart area as attached.
This code:
gives me this result, without the borders you mention:
Priyanka
Post by Priyanka » Wed Jun 01, 2016 9:13 am
Hi Christopher,
I think you got confused. I need top and bottom border to only chart area.
Post by Christopher » Wed Jun 01, 2016 10:58 am
You might like to try the different variations in this code yourself until you come across the combination that most adapts to your needs:
    WebChart1.Chart.Panel.Gradient.Visible = false;
    WebChart1.Chart.Panel.Color = Color.White;
    WebChart1.Chart.Panel.Bevel.Inner = Steema.TeeChart.Drawing.BevelStyles.None;
    WebChart1.Chart.Panel.Bevel.Outer = Steema.TeeChart.Drawing.BevelStyles.None;
    WebChart1.Chart.Aspect.View3D = false;
    WebChart1.Chart.Series.Add(typeof(Line)).FillSampleValues();
    //#1
    //WebChart1.Chart.Walls.Visible = false;
    //WebChart1.Chart.Axes.Visible = false;
    //#2
    //WebChart1.Chart.Walls.Back.Gradient.Visible = false;
    //WebChart1.Chart.Walls.Back.Color = Color.White;
    //WebChart1.Chart.Walls.Back.Pen.Color = Color.Red;
    //WebChart1.Chart.Axes.Left.AxisPen.Visible = false;
    //WebChart1.Chart.Axes.Bottom.AxisPen.Visible = false;
    //#3
    WebChart1.Chart[0].VertAxis = VerticalAxis.Both;
    WebChart1.Chart[0].HorizAxis = HorizontalAxis.Both;
    WebChart1.Chart.Axes.Top.AxisPen.Color = Color.Yellow;
    WebChart1.Chart.Axes.Top.Labels.Visible = false;
    WebChart1.Chart.Axes.Right.AxisPen.Color = Color.Blue;
    WebChart1.Chart.Axes.Right.Labels.Visible = false;
Priyanka
Post by Priyanka » Thu Jun 02, 2016 9:41 am
Thanks Christopher. I will try it.
Need your help to implement requirement of showing blank report. As per attached screenshot. We need to draw series for some date range and rest should be blank.
Post by Christopher » Mon Jun 06, 2016 8:27 am
Priyanka wrote:Need your help to implement requirement of showing blank report. As per attached screenshot. We need to draw series for some date range and rest should be blank.
Can you not simply set the bottom Axis's SetMinMax to a relevant value? Or is the situation more complex than this? If so, how?
Priyanka
Post by Priyanka » Mon Jun 06, 2016 8:41 am
Hi Christopher,
SetMinMax function doesn't work. Below is the code I am using. However, it is not setting minimum to 0.2 and maximum to 200.
WebChart1.Chart[0].CustomVertAxis.Automatic = false;
WebChart1.Chart[0].CustomVertAxis.SetMinMax(0.2, 200);
WebChart1.Chart[0].CustomVertAxis.Labels.ValueFormat = "##0.##;{##0.##}";
Value format is also set. Not sure why the SetMinMax function is not working.
Need urgent help. Thanks.
Post by Christopher » Tue Jun 07, 2016 9:17 am
Hello!
This code:
    protected void Page_Load(object sender, EventArgs e)
      Chart chart = WebChart1.Chart;
      chart.Aspect.View3D = false;
      chart.Series.Add(typeof(Line)).FillSampleValues();
      chart.Panel.MarginLeft = 30;
      Axis axis = chart.Axes.Custom.Add();
      axis.Horizontal = false;
      axis.RelativePosition = -40;
      axis.PositionUnits = PositionUnits.Percent;
      axis.SetMinMax(200, 300);
      chart[1].CustomVertAxis = axis;
gives me the following (depending on the random values of FillSampleValues, of course):
Priyanka
Post by Priyanka » Tue Jun 07, 2016 11:48 am
Hi Christopher,
Please taka a look in the attached code.
Appreciate quick help.
SetMinMax.zip
(63.83 KiB) Downloaded 621 times
Priyanka
Post by Priyanka » Wed Jun 08, 2016 7:06 am
Hi Christopher,
Any updates on the issue?
Post by Christopher » Wed Jun 08, 2016 1:56 pm
Priyanka wrote:Hi Christopher,
This is the result of running the code you sent:
I'm afraid to say that I'm not entirely sure what the issue is you refer to. Could you please be more specific?
Priyanka
Post by Priyanka » Thu Jun 09, 2016 4:52 am
Hi Christopher,
Attached is the output of the code shared by me. Not sure why the below code is not working in case of custom vertical axis
WebChart1.Chart[0].CustomVertAxis.SetMinMax(0.3, maxvalue);
Also, need inputs on setting chart resolution and exporting chart in binary format.
Appreciate your help.
Post by Christopher » Thu Jun 09, 2016 8:44 am
It is working here. This code:
        WebChart1.Chart[0].CustomVertAxis.SetMinMax(maxvalue - (maxvalue / 10), maxvalue);
gives me this:
Priyanka wrote: Also, need inputs on setting chart resolution and exporting chart in binary format.
What help do you need, exactly?
