Chart.Bitmap threw an exception.
I try to draw when ever there is change in the value of the textbox in C# application.
E.g., diameter=8.323232
If I change the above value slowly like 8.32323, 8.3232 and so on by pressing backspace I have no problems the charts renders the change in the value.
But if I change the values very fast by pressing backspace two or more times continuously I get an exception in Chart.Bitmap.
System.NullReferenceException was unhandled
HResult=-2147467261
Message=Object reference not set to an instance of an object.
Source=TeeChart
StackTrace:
at Steema.TeeChart.Tools.SeriesBandTool.DrawBandTool()
at Steema.TeeChart.Tools.SeriesBandTool.BeforeDrawValues(Object sender, Graphics3D g)
at Steema.TeeChart.PaintChartEventHandler.Invoke(Object sender, Graphics3D g)
at Steema.TeeChart.Styles.Series.DoBeforeDrawValues()
at Steema.TeeChart.Styles.Series.DrawSeries()
at Steema.TeeChart.Chart.DoDraw(Graphics3D g, Int32 First, Int32 Last, Int32 Inc)
at Steema.TeeChart.Chart.DrawAllSeries(Graphics3D g)
at Steema.TeeChart.Chart.InternalDraw(Graphics g, Boolean noTools)
at Steema.TeeChart.Chart.Draw(Graphics g, Rectangle r, Boolean noTools)
at Steema.TeeChart.Chart.Draw(Graphics g)
at Steema.TeeChart.Chart.Bitmap(Int32 width, Int32 height, PixelFormat pixelformat)
at Steema.TeeChart.Chart.Bitmap(Int32 width, Int32 height)
at Steema.TeeChart.TChart.get_Bitmap()
at *some namespace*.AddChartView() in ..\Control.cs:line 805 *This line is edited by me*
at System.Windows.Forms.Control.OnTextChanged(EventArgs e)
at System.Windows.Forms.TextBoxBase.OnTextChanged(EventArgs e)
at System.Windows.Forms.TextBoxBase.WmReflectCommand(Message& m)
at System.Windows.Forms.TextBoxBase.WndProc(Message& m)
at System.Windows.Forms.TextBox.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.DebuggableCallback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
InnerException:
HResult=-2147467261
Source=TeeChart
StackTrace:
InnerException:
- Guru
Re: Chart.Bitmap threw an exception.
Would you please be so kind as to post here a Short, Self Contained, Correct (Compilable), Example with which we can reproduce your issue?Raavi wrote: But if I change the values very fast by pressing backspace two or more times continuously I get an exception in Chart.Bitmap.
I am trying to reproduce the problem with spike solution but I did not find much time to do that but,
the problem is when I try to add a line series to
var seriesBandTool = new SeriesBandTool();
seriesBandTool.Series = //line series
Chart.Tools.Add(seriesBandTool);
and change the //line series really fast with change in value of a textbox.
StackTrace
at Steema.TeeChart.Tools.SeriesBandTool.DrawBandTool()\r\n
at Steema.TeeChart.Tools.SeriesBandTool.BeforeDrawValues(Object sender, Graphics3D g)\r\n
at Steema.TeeChart.PaintChartEventHandler.Invoke(Object sender, Graphics3D g)\r\n
at Steema.TeeChart.Styles.Series.DoBeforeDrawValues()\r\n
at Steema.TeeChart.Styles.Series.DrawSeries()\r\n
at Steema.TeeChart.Chart.DoDraw(Graphics3D g, Int32 First, Int32 Last, Int32 Inc)\r\n
at Steema.TeeChart.Chart.DrawAllSeries(Graphics3D g)\r\n
at Steema.TeeChart.Chart.InternalDraw(Graphics g, Boolean noTools)\r\n
at Steema.TeeChart.Chart.Draw(Graphics g, Rectangle r, Boolean noTools)\r\n
at Steema.TeeChart.Chart.Draw(Graphics g, Rectangle r)\r\n
at Steema.TeeChart.Chart.Metafile(Graphics gRef, Stream stream, Chart aChart, Int32 width, Int32 height, EmfType type)\r\n
at Steema.TeeChart.Chart.Metafile(Stream stream, Chart aChart, Int32 width, Int32 height, EmfType type)\r\n
at Steema.TeeChart.Chart.Metafile(Chart aChart, Int32 width, Int32 height)\r\n
at Steema.TeeChart.TChart.get_Metafile()"
Screen-shot of the exception.
- BitMapException.png (94.07 KiB) Viewed 17326 times
- Guru
When you say, "change the line series", what do you mean exactly? Using the following code I cannot reproduce the issue here:Raavi wrote:and change the //line series really fast with change in value of a textbox.
System.Windows.Forms.Timer timer = new System.Windows.Forms.Timer();
Line line1;
timer.Tick += Timer_Tick;
line1 = new Line(tChart1.Chart);
line1.FillSampleValues();
SeriesBandTool tool = new SeriesBandTool(tChart1.Chart);
tool.Series = line1;
timer.Interval = 1;
timer.Start();
private void Timer_Tick(object sender, EventArgs e)
I am stilling try to reproduce this exception outside of my project but still no success.
at Steema.TeeChart.Chart.Draw(Graphics g)\r\n
at Steema.TeeChart.Chart.Bitmap(Int32 width, Int32 height, PixelFormat pixelformat)\r\n
at Steema.TeeChart.Chart.Bitmap(Int32 width, Int32 height)\r\n
at Steema.TeeChart.TChart.get_Bitmap()"
These are from stack trace. I am still trying to reproduce the bug outside of my project.
- Guru
Why have you got calls to get_Bitmap() and get_Metafile()? These should not be in any normal stacktrace, as they are not called unless done so specifically in user code.Raavi wrote:"
I do not call anything expect adding 'SeriesBandTool' to chart.
I hope, I can succeed in reproducing this exception in spike solution.
