Exception with Series Band
Seveno Developer
Post by Seveno Developer » Thu Nov 05, 2015 11:48 pm
Hello Help desk,
We are having issues with Series Band tool.
When a user adds a series band from the chart editor without selecting Series2 and tries to delete series band that contains only one series, the application breaks.
We need to handle this exception.
Is there any way to handle the add series band event and assign "Series" value to "Series2" value by default?
Thanks in advance
Khaled
Re: Exception with Series Band
Post by Christopher » Fri Nov 06, 2015 4:23 pm
Hello Khaled,
Can you reproduce this issue by code, or does it only happen in the chart editor?
Seveno Developer
Post by Seveno Developer » Sun Nov 08, 2015 10:54 pm
Hi Christopher,
We are not coding the series band feature since we do not want the series band to be added by default.
Our users may optionally add series bands using the chart editor.
Steps to reproduce:
1. Add a series
2. Assign random values into the series data source
3. Add a series band from tools
4. Select series: <Name of the series that you added>
5. Delete the series band
Kind regards
Khaled
Post by Christopher » Mon Nov 09, 2015 9:33 am
Hello Khaled,
I have been able to reproduce this problem here and have added it to our issue tracking software with id=1367. This issue has now been fixed, and the fix required the following source code change:
This change will be made public with the next TeeChart maintenance release.
Seveno Developer
Post by Seveno Developer » Tue Nov 10, 2015 1:21 am
Hi Christopher
Thanks for resolving the issue. It is so nice to have such an awesome tool and prompt help from you guys.
Kind regards
Khaled
Post by Christopher » Tue Nov 10, 2015 9:03 am
Thank you very much Khaled, you're very welcome!
