Synchronizing Cursor Behaviour
Quant
Post by Quant » Thu Mar 26, 2015 4:17 am
We have a problem while synchronizing cursor tool with two charts. It gives us performance issue, as second chart's cursor coordinates lags behind first chart's cursor coordinates. We successfully synchronized both cursor tools, but we have speed issue.
Re: Synchronizing Cursor Behaviour
Post by Narcís » Thu Mar 26, 2015 9:08 am
Hello Quant,
Are you doing something as in the All Features\Welcome !\Tools\Cursor\Synchronizing Two example at the features demo available at TeeChart's program group? Does this perform slowly for you?
If the problem persists, could you please attach a Short, Self Contained, Correct (Compilable), Example?
Quant
Post by Quant » Thu Mar 26, 2015 12:07 pm
Please find attached sample code.
WindowsFormsApplication2.zip
(19.41 KiB) Downloaded 1154 times
This is not actual logic that we have used in our final product. But in this sample application also it gives us performance issue. It is very similar to your sample code.
Post by Narcís » Fri Mar 27, 2015 12:23 pm
Hi Quant,
I see a little lag in the demo but not in your application. Should I do anything specific to reproduce it?
Quant
Post by Quant » Mon Mar 30, 2015 5:26 am
We are seeing lag in the attached sample application also. I am very surprised that you didn't get any lag in our attached sample application.
It gets lagged while dragging mouse cursor.
Post by Christopher » Mon Mar 30, 2015 9:12 am
Quant wrote:We are seeing lag in the attached sample application also. I am very surprised that you didn't get any lag in our attached sample application.
The lag can be significantly reduced by using code such as:
        bool isCursorTool1, isCursorTool2;
            this.Load += new EventHandler(Form1_Load);
            cursorTool1.Change += new Steema.TeeChart.Tools.CursorChangeEventHandler(cursorTool1_Change);
            cursorTool2.Change += new Steema.TeeChart.Tools.CursorChangeEventHandler(cursorTool2_Change);
            tChart1.MouseMove += tChart1_MouseMove;
            tChart2.MouseMove += tChart2_MouseMove;
        void tChart1_MouseMove(object sender, MouseEventArgs e)
          isCursorTool1 = true;
          isCursorTool2 = false;
        void tChart2_MouseMove(object sender, MouseEventArgs e)
          isCursorTool1 = false;
          isCursorTool2 = true;
        void cursorTool2_Change(object sender, Steema.TeeChart.Tools.CursorChangeEventArgs e)
          if(isCursorTool2)
            cursorTool1.XValue = cursorTool2.XValue;
            cursorTool1.YValue = cursorTool2.YValue;
        void cursorTool1_Change(object sender, Steema.TeeChart.Tools.CursorChangeEventArgs e)
          if(isCursorTool1)
            cursorTool2.XValue = cursorTool1.XValue;
            cursorTool2.YValue = cursorTool1.YValue;
        void Form1_Load(object sender, EventArgs e)
            this.tChart1[0].FillSampleValues(40);
            this.tChart2[0].FillSampleValues(40);
            this.tChart1.Axes.Left.Labels.CustomSize = 50;
            this.tChart2.Axes.Left.Labels.CustomSize = 50;
Quant
Post by Quant » Mon Mar 30, 2015 11:53 am
I tried your sample code, but the result is not satisfactory. It still lags on large sample values (I checked the same on 1000 data points).
Please help us in the same asap.
Post by Christopher » Mon Mar 30, 2015 12:35 pm
Quant wrote:Hi,
If you are using 1000 points in each series then you will need to use Downsampling, as shown in the features demo (%Program Files%\Steema Software\Steema TeeChart for .NET 2015 4.1.201X.XXXXX\Examples\DemoProject\bin\ExecutableDemo\TeeChartNetExamples.exe) under:
All Features -> Welcome !\Functions\Extended\Reducing number of points
The issue here is that the .NET Framework does not paint the two charts simultaneously, it paints them one after the other, and given that a large number of points means a longer time for painting which produces the "lag".
Quant
Post by Quant » Tue Mar 31, 2015 5:25 am
We tried the downsampling on our previously attached sample code. But still it is giving the same problem.
Please have a look on the attached code snippet and let us know if we are doing anything wrong in this.
        private Steema.TeeChart.Functions.DownSampling downSampling1;
            downSampling1 = new Steema.TeeChart.Functions.DownSampling(tChart1.Chart);
            cursorTool1.Active = true;
            cursorTool2.Active = true;
            colorLine1.Active = false;
            colorLine2.Active = false;
            if (isCursorTool2)
            if (isCursorTool1)
            downSampling1.DisplayedPointCount = 1000;
            downSampling1.Method = Steema.TeeChart.Functions.DownSamplingMethod.MinMaxFirstLastNull;
            this.tChart1[0].FillSampleValues(1000);
            this.tChart2[0].FillSampleValues(1000);
            this.tChart1[0].Function = downSampling1;
            this.tChart2[0].Function = downSampling1;
What are the alternative method to do the above things without any lag?
Post by Christopher » Tue Mar 31, 2015 9:32 am
Quant wrote:What are the alternative method to do the above things without any lag?
I have already tried to explain to you that no lag in these circumstances is impossible. As I said, "The issue here is that the .NET Framework does not paint the two charts simultaneously, it paints them one after the other, and given that a large number of points means a longer time for painting which produces the "lag"."
Here is a video of cursor synchronization using 10,000 points in each Chart (this on a relatively old machine):
http://screencast.com/t/rWrDxjDmZsXy
And here is the code I used:
   public SurfaceTest_Form()
      InitializeChart();
    CursorTool cursorTool1, cursorTool2;
      tChart2.Aspect.View3D = false;
      tChart2.Legend.Visible = false;
      tChart1.Panel.Gradient.Visible = false;
      tChart2.Panel.Gradient.Visible = false;
      tChart1.Panel.Visible = false;
      tChart2.Panel.Visible = false;
      tChart1.Walls.Back.Gradient.Visible = false;
      tChart2.Walls.Back.Gradient.Visible = false;
      tChart1.Walls.Back.Visible = false;
      tChart2.Walls.Back.Visible = false;
      cursorTool1 = new CursorTool(tChart1.Chart);
      cursorTool2 = new CursorTool(tChart2.Chart);
      cursorTool1.FollowMouse = true;
      cursorTool2.FollowMouse = true;
      FastLine series1 = new FastLine(tChart1.Chart);
      FastLine series2 = new FastLine(tChart2.Chart);
      series1.DrawAllPoints = false;
      series2.DrawAllPoints = false;
      if (isCursorTool2)
      if (isCursorTool1)
      this.tChart1[0].FillSampleValues(10000);
      this.tChart2[0].FillSampleValues(10000);
I think the lag is noticeable, but not unacceptably so.
Quant
Post by Quant » Tue Mar 31, 2015 11:22 am
Hi Christopher,
We are using following sample code which significantly improves cursor performance.
We tested the below code on 100, 1000 and 10000 sample points, and we find very little lag on 1000 sample points and a significant lag on 10000 sample point. These tests proved the performance improvement of cursor tool.
We used FastCursor Property of cursor tool to improve the performance. It would be very great if you can improve the below code to remove lag while plotting 10000 sample point.
              InitializeChart();
              cursorTool1.FastCursor = isCursorTool1;
              cursorTool2.FastCursor = isCursorTool2;
              cursorTool1.Style = Steema.TeeChart.Tools.CursorToolStyles.Both;
              cursorTool2.Style = Steema.TeeChart.Tools.CursorToolStyles.Vertical;
              cursorTool1.Style = Steema.TeeChart.Tools.CursorToolStyles.Vertical;
              cursorTool2.Style = Steema.TeeChart.Tools.CursorToolStyles.Both;
              if (isCursorTool2)
              if (isCursorTool1)
              this.tChart1[0].FillSampleValues(100);
              this.tChart2[0].FillSampleValues(100);
As per our requirements we must achieve this. It is unacceptable to our users. What do you say about using multithreading?
Post by Christopher » Tue Mar 31, 2015 1:12 pm
Quant wrote: As per our requirements we must achieve this. It is unacceptable to our users. What do you say about using multithreading?
I'm afraid GDI+ does not support multithreading, we had a long look into this issue a few years ago.
