Support for Windows 8.1
alvis
Post by alvis » Tue Dec 23, 2014 5:54 am
We are working on a C# software that uses TeeChart v2010, and are looking into the possibility to support our software in Windows 8.1.
We would like to check with you whether TeeChart v2010 (TeeChartNET2010VSNET2008_4.0.2010.27962) has been tested in Windows 8.1.
If no, then which version of TeeChart is tested in Windows 8.1?
Re: Support for Windows 8.1
Post by Yeray » Tue Dec 23, 2014 10:00 am
I see no reason why it shouldn't work. Have you tried it? Have you found any problems with it?
I've just checked the same build works fine for me for Visual Studio 2010 in a Windows 8.1 machine, so I'd assume it should also work fine with Visual Studio 2008.
alvis
Post by alvis » Wed Dec 24, 2014 1:23 am
Which version of TeeChart officially support Windows 8.1?
Post by Yeray » Wed Dec 24, 2014 9:09 am
alvis wrote:Which version of TeeChart officially support Windows 8.1?
I think we haven't identified any old version as not usable in Windows 8.1.
Are you finding troubles with any concrete version or do you want us to check any concrete version?
alvis
Post by alvis » Fri Dec 26, 2014 1:46 am
Yeray wrote:Hello,
Does it mean that testing has been done for TeeChart v2010 on Windows 8.1?
We have not tested on our software on Windows 8.1 yet.
Post by Narcís » Mon Dec 29, 2014 9:15 am
Hi Alvis,
alvis wrote: Does it mean that testing has been done for TeeChart v2010 on Windows 8.1?
Probably not. As you can read here, Windows 8.1 was made available to the public on the second half of 2013. This means the TeeChart version available at that time was TeeChart for .NET v2013 and tests were done with that version. We haven't heard of any customer having problems with Windows 8.1 so we wouldn't expect anything being wrong with v2010. Actually, v2010 is the same internal version (v4) than v2013 and v2014, the product name referencing the year is just a commercial name to go in sync with the subscription licensing system.
