Please find attached an example of what I want to achieve, i.e. creating a stacked imagebar graph. The problem is that the image is not loading. I'm also unable to find any proper samples of using the imagebar.
Thank you
Casper
Silverlight ImageBar
- LithologyImageTest.zip
- (24.99 KiB) Downloaded 543 times
- Guru
Re: Silverlight ImageBar
There are two things happening here. Firstly, the image Aeolianite.png is not displaying because its "Build Action" is set to "Embedded Resource" - if you set this to "Resource" then the image will display. Secondly, unfortunately, it seems that the ImageTiled property is not implemented in Silverlight, a defect which is now in our database as id=1017. At the moment then, setting this property to true will produce a bar without an image on it.cjherasmus wrote:Please find attached an example of what I want to achieve, i.e. creating a stacked imagebar graph. The problem is that the image is not loading. I'm also unable to find any proper samples of using the imagebar.
Hi Christopher,
This is a serious problem for me now. I had a look at the full demo that comes with the software and the imagebar is also not tiling there.
Hi Christopher,
Is there an temporary solution for me or would I have to wait until the defect is fixed?
Approximately how long would it take to have a solution for the defect?
- Guru
I had a look at this issue a couple of days ago and was unable to fix it, and neither can I suggest a workaround. However, I do see a possibility with the ImageBrush class. The next maintenance release is due out within the next fifteen days, so if a fix using this class is possible it will be included in it.cjherasmus wrote: Is there an temporary solution for me or would I have to wait until the defect is fixed?
Thank you for the feedback Christopher, I'll keep a lookout.
