Transparency is not correctly exported to some formats
Dear support:
I noticed that transparent color is not correctly exported to some image formats, such as PDF, EPS, HTM, and GIF (which I assume is due to the number of colors supported by GIF format). Any fixes?
Jeff
Jeff
Hi Jeff,
Yes, that's right, transparency exporting is not supported. I've added your request to our wish-list to be considered for inclusion for future releases.
Re: Transparency is not correctly exported to some formats
Hello.
This issue has been pending now for nearly 3 years. Can it PLEASE be addressed?
Longingly,
Richard.
Longingly,
Richard.
Hello Richard,
I have tested your bug and I confirm that when you export image as GIF format, now works fine using last version of TeeChart .Net.
Moreover, I have increased and modified feature request (TF02012471), and we try to solve problem of other formats (PDF,HTM,EPS) to be considered for inclusion in future releases
Has there been any progress on this issue?
Hello drrms,
I am sorry, not yet
I am sorry, not yet
Hello.Sandra wrote:Hello Richard,
We have tried the latest TeeChart version and made simple project, that exports chart with transparent background to different formats. All formats, including GIF still comes with black background, instead of transparent. Project archive and gif example in the attach.
- SteemaTestProject.rar
- Sample project
- (24.14 KiB) Downloaded 728 times
Hello Richard,
I tested your project, and I foun that changing next line of code:
for it line:
And adding in ExportButton it:
Background color seems its transparent now. Could you please, check if you are changing first line of code for second line, works fine for you?
I hope will helps.
TChart.Panel.Color = Color.Transparent;
TChart.Panel.Transparent = true;
private void ExportButton_Click(object sender, EventArgs e)
Steema.TeeChart.Drawing.BufferStyle buffer = TChart.Graphics3D.BufferStyle;
TChart.Graphics3D.BufferStyle = Steema.TeeChart.Drawing.BufferStyle.None;
switch (ComboBox.SelectedIndex)
case 0:
Export(new BitmapFormat(TChart.Chart));
break;
case 1:
Export(new GIFFormat(TChart.Chart));
break;
case 2:
Export(new JPEGFormat(TChart.Chart));
break;
case 3:
Export(new PNGFormat(TChart.Chart));
break;
TChart.Graphics3D.BufferStyle = buffer;
I hope will helps.
Hi.
We have trued suggested solution. Attached archive contains four different outputs. The result is different from what was expected. Bmp, gif, jpg does not present transparency at all. Png gives transparency but renders text using some different font.
- export.rar
- Four export results
- (117.61 KiB) Downloaded 754 times
Hello Richard,
I could check your problems with exporting and I have added these in bug list report with number [TF02015339]. We will try to fix it for next maintenance releases of TeeChart.Net.
