Huge margins on plots with long rotated axis labels
Michal Blazejczyk
Post by Michal Blazejczyk » Tue Jun 01, 2010 2:57 am
We are a few versions behind with TeeChart (3.5.3188.18561), but all has been working fine until now... We have a few charts with fairly long bottom axis labels, so we are rotating the text. The problem is that this leaves huge white margins under the chart...
Steema - Huge margin.png (7.45 KiB) Viewed 9925 times
Is there a way to fix this? We would rather not update to a recent version of TeeChart because there are always many backward-compatibility issues, and we simply have no time for that.
Best,
Michal
Best,
Michal Blazejczyk
Lead Programmer
Genome Quebec
Re: Huge margins on plots with long rotated axis labels
Post by Yeray » Wed Jun 02, 2010 12:14 pm
Hi Michal,
Yes, I've seen that the bottom margin calculated when having long bottom axis labels with an oblique angle seems to be like the angle were 90.
I've added it to the defect list to be revised in future releases (TF02014926).
Michal Blazejczyk
Post by Michal Blazejczyk » Wed Jun 02, 2010 3:19 pm
Does it mean that it doesn't work well in even recent versions, either? That's sad... :(
Best,
Michal
Post by Yeray » Wed Jun 02, 2010 3:30 pm
Hi Michal,
What I've seen is that we fixed a similar problem some time ago that may be related (TF02013509) but it's not exactly the same.
Michal Blazejczyk
Post by Michal Blazejczyk » Thu Jun 03, 2010 10:44 pm
In this case I'm even more surprised because issue TF02013509 you mention is a manifestation of the same problem that I described. It was reported in October 2008, and it is still not fixed???
Could you suggest a workaround, i.e. a way of detecting this situation, and manually making the plot area bigger so that there is no white space under the axis labels?
Best,
Michal
Best,
Michal Blazejczyk
Lead Programmer
Genome Quebec
Post by Narcís » Fri Jun 04, 2010 11:40 am
Hi Michal,
It seems TF02013509 fixed this for labels at 90 degrees but not for other possible values :(
What about something as the code below? You can tweak the AfterDraw event a little bit to enhance the workaround.
			InitializeChart();
      string label = "this is a very long label for testing";
      line1.Add(3, label);
      line1.Add(5, label);
      line1.Add(7, label);
      line1.Add(2, label);
      tChart1.Axes.Bottom.Labels.Angle = 0;
      tChart1.GetAxisLabel += new Steema.TeeChart.GetAxisLabelEventHandler(tChart1_GetAxisLabel);
      Timer timer1 = new Timer();
      timer1.Interval = 1000;
      timer1.Tick += new EventHandler(timer1_Tick);
      timer1.Enabled = true;
      int angle = tChart1.Axes.Bottom.Labels.Angle;
      if (angle != 0)
        int labelSize = tChart1.Axes.Bottom.MaxLabelsWidth();
        double factor = Math.Sin(angle);
        double margin = labelSize * Math.Abs(factor);
        tChart1.Panel.MarginUnits = Steema.TeeChart.PanelMarginUnits.Pixels;
        tChart1.Panel.MarginBottom = margin;
    void timer1_Tick(object sender, EventArgs e)
      tChart1.Axes.Bottom.Labels.Angle = (tChart1.Axes.Bottom.Labels.Angle + 10 % 360);
    void tChart1_GetAxisLabel(object sender, Steema.TeeChart.GetAxisLabelEventArgs e)
      if (sender.Equals(tChart1.Axes.Bottom))
        if (e.LabelText.Length > 15)
          e.LabelText = string.Format("{0}{1}", e.LabelText.Substring(0, 15), "...");
